I just bought a 2003 Chevy Malibu. The gas gauge always reads empty. The low fuel light is on. The fuel pump was just changed. Any ideas?
SOURCE: Where does the flasher go on a 98 chevy malibu
Replacement
The turn and hazard flashers are integrated into one flasher on these models. The flasher is located in the hazard warning switch and the hazard warning switch is located on the trim plate. Replace the flasher by unplugging the old one, removing it from the panel, and plugging in the new one.
Remove the bezel from the ignition switch
Carefully remove the instrument panel accessory trim plate.
To remove the trim plate, use a suitable prytool to carefully apply pressure at the retaining clip points . . .
. . . then gently pull the accessory trim plate away
Detach the electrical connector from the hazard warning switch.
Unplug the electrical connector from the hazard warning switch . . .
Unfasten the screw securing the hazard warning switch and remove the switch.
. . . then unfasten the screw securing the hazard warning switch and remove the switch from the vehicle
Installation is the reverse of removal.
Testimonial: "just what I needed, thank you so much."
SOURCE: theft system passlock on 2003 chevy malibu. theft
yr gonna have to get the passlock key and punch it into the radio so u can solve ur problem most chevy dealships can assist you with that.
SOURCE: gas gauge malfunction and engine light stays on
This is a common problem with Malibu's. It is due to cheap metal in the fuel gage that corrodes. Chevrolet knows about this but they refuse to issue a fix. The check engine light staying on and the faulty fuel gage are related. This is a defect and they need to recall this part! Raise hell with the dealership!
SOURCE: 2002 Chevy Malibu. ABS light
The abs light will reset every time the vehicle is shut off. The most common cause of the abs light coming on is a bad wheel speed sensor. A scan tool would be the option to locate the fault in the abs system.
loser
I filled the tank. The gas guage hasn't moved once and I put 200 miles on the vehicle.
How much did it cost to repair?
