I have a RCA television,model HD61LPW62 with a cracked lamp. So the lamp was replaced;now the set makes a scratching noise when it tries to power up.after about a minute the sound stops then a minute later it starts again.this goes on and on. can you help me with probable cause ?
  • jimmiecooper Oct 20, 2008
    can you narrow the problem down to one board and location within the set ?
    I fail to mention that the set has no video at all because it will not power up. I feel like if a board # can be given it would help greatly with the scratching sound problem.
  • 54 Answers
I think u have to change the capacitor which is the cause for making such noise
Posted on Oct 20, 2008
    Master:
  • 538 Answers
    Scholar:
  • 77 Answers
Hey Jim,
There would be a capacitor shaped like a black bottle on the board which needs to be replaced. The new tube you have installed seems to need more power then your current capacitor can provide. If this keeps on happening you may end up burning out the capacitor. get a new one with a higher power rating.
Hit me again if you need more info.
  • 53 Answers
The capacitors in your television need to charge up when the unit is first turned on. You need to replace them if the noise gets much longer.
    Master:
  • 848 Answers
Check the connection in your tv..........the noise is produced due to bad solder in you tv ..........
check the capacitors....
  • gopinath pasupathy Oct 20, 2008
  • Excessive load or faulty power supply cycling on its overcurrent protection circuit.
  • High voltage shutdown, or some other system detecting an out of regulation condition.
  • A dried up main filter capacitor or other filter capacitor in the low voltage power supply that is producing an out-of-regulation condition until it warms up. A bad filter capacitor on the output of a series regulator may result in excessive voltage and subsequent shutdown.
  • A problem with the microcontroller, relay or its driver, or standby power supply
MY SAMSUNG TV MODEL PCJ522R IS MAKING A CLICKING SOUND AND THE POWER LIGHT IS ON BUT TV WONT COME ON
Issue with the light ballast trying to light your lamp and it can't. Either a bad lamp (90%) - could be cracked or imploded or a bad lamp starter (10%).
Nov 12, 2014 | Televison & Video
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tv hd61lpw62 power button blinks five times and wont turn on tv
i have a rca hd61lpw62 makes loud noise and i lose the picture still have sound tv repair man fixed it once and said he had to soilder ballist one month later doing the same thing this time he said it was the color wheel sounds like he is just guesssing you can wait a few moments and it comes back on help please
May 04, 2010 | RCA Televison & Video
Dark picture!
The Lamp it self, the Ballast, or the Power Supply that powers the Ballast. Even a combination of the Lamp and Power Supply is a common problem. If you have not replaced the Lamp since you have owned the set I would replace that first. The Lamp has about a 3000 to 5000 hour life span.
Hope this helps,
Skyassoc
Jul 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Whining noise on start up, lamp and TV shutting down
The TV tech isnt too familliar with RCA TVs. The color wheel is the most likely problem no where near 1000. Depending on the model number of your set you can get replacement color wheels at the following link.
http://servicemanuals.vstore.ca/
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Tv has sound but no picture
my rca hd model hd50lpw164 has no picture. some sound and a electrical popping noise.
supect the lamp is out.
where can i obtain new lamp and whats the cost.?
david
Nov 20, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
Powers on. green light flashes then turns back off.
For troubleshooting your lamp, use the following lamp troubleshooting wizard here:
http://www.fixyourdlp.com/wizard/launch-window.html
If it turns out you need a lamp, you can follow the simple instructions available here for just about any make and model, including your RCA. The RCA website is useless and they never have parts in stock.
http://guides.fixyourdlp.com/guides.php
Oct 09, 2008 | RCA HD52W58 52" TV
PT-.. NO POWER NO SOUND
yes if the lamp doesnt light the set cant complete the boot sequence. replace the lamp and your set should be fine.
Apr 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
