Dell E173FP  17 in. Flat Panel LCD Monitor
Problem for Dell E173FP (Black) 17 in. Flat Panel LCD Monitor
Repeated power cycles after a couple of hours running.
By harisn9000 on Jun 28, 2006
I've got a Dell 17" flat-panel monitor and it repeatedly power cycles when turned on. It seems to work fine for a few hours and then begins the continuous power cycle. Any thoughts on this one?
I almost completely dismantled the monitor to see if there were any loose or damaged cables and put it back together and it still seems to do this. Almost like something is overheating? The power supply? Can these be replaced at a reasonable cost if so?
Comments:
Jun 28, 2006
- Thanks for the feedback so far. I am currently waiting for it to fail again so I can provide you with a "yes/no" anwer to your question. Last time it seemed to run for about 2 days and then fritz out.
Jun 29, 2006
- Okay, it finally started doing the power-cycle thing again. The monitor just went black and the power light cycles and during this power cycle, the screen also acts like it is going to turn on (you can see the black screen slightly backlit)and then it just goes back off again.
Oddly enough, this time, it did this for about a minute and then came back on by itself. When it did finally come back on, the screen was flickering slightly (similar to when you just turn on an older flourescent light).
Anyway, it happened and now it is working again. Any other thoughts?
Same Problem
Nov 09, 2007
-   I have aquired a few of these sceptre monitors doing this same thing and would like to find out more about unclejeds solution of the dried out cap.
-   kevsplace
Nov 03, 2007
-   Monitor cycles on and off non stop.never really on all the way.-   poopoobutt
Best Solution
posted on Feb 09, 2008
Very Helpful)
Doogieman104
Rank: Apprentice
Rating: 100%, 1 votes
I have a Dell 15" Flat Panel with the same symptoms. I found that if I tapped on the monitor, it would work for awhile which suggested a loose connection. I dismantled the monitor and removed the main board so that I could see the soldered connections. With the board positioned with the power connection facing away from me, I inspected all solder joints on the main board using a magnifying glass. On the left side, I saw two capacitors and found insufficient solder around the leg of one of the capacitors. I touched a soldering iron with a small dab of solder to the connection. After reassembling, I have experienced no further cycling. Going on two weeks now, it seems to have cured the problem.
Was this helpful?
Yes
No
Solution #2
posted on Jun 28, 2006
Very Helpful)
unclejed
Rank: Master
Rating: 85%, 207 votes
before it goes out, does the picture compress on one of the sides?
it's possible the horizontal output transistor is overheating. this is usually caused by a dried out electrolytic capacitor in the driver circuit. if you're not sure what i'm talking about, have it repaired. if you understand what i just said, i'd be glad to help you find the problem.
Was this helpful?
Yes
No
Popular Solutions for Dell E173FP 17 in. Flat Panel
Questions and Unsolved Problems for Dell E173FP 17 in. Flat Panel
Do you recommend Dell E173FP (Black) 17 in. Flat Panel LCD Monitor?
Answer
Answer
my lcd display dell E173fpf doesn't start no light nothing
Answer
monitor starts for an instant and fades to black screen
Answer
it has a band of pixelated spots down the center third of the screen
Answer
can I get Model numbers from serial numbers on various different flat panel monitors?
Answer
Dell flat panel monitor ST2010 - everything appears stretched out -- how do I correct this?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell E173FP 17 in. Flat Panel...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
