Question about Sony Cyber-shot DSC-W50 Digital Camera
DSC W 30
My flash will not work and an error message comes on the screen and blinks... I tried the method of re-initializing but that does not seem to work. Anything else i can try?
  • lilqban Nov 02, 2008
    i turn on the camera and i recieve a error message and the flash blinks with it a take a picture and the flash wont come out... how can i fix it
  • 74 Answers
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Posted on Nov 03, 2008
My sony DSC-w120 digital camera flash is not working.Please tell me how to rectify the same
If there is error message on the display and blinking flash, try to initialize the camera. If the problem persists or there is no error message, there is probably no user solution, camera will have to be repaired by service personnel.
May 20, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flashing E62:12 on screen?
Check error still comes after RESET camera by going into camera Menu -> Initialize ->OK
E62:12 is error code means "Lens Overheating". Camera has "Angular Velocity Sensor" on its main board and that can be cause of problem. If still error blinks, contact Sony Service Center for proper fix as this will requires special tools.
Feb 25, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Sony DSC-W50 Flash Error code-E:91:01
Press Menu button
Oct 08, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Error E91:01 on DSC H7
I had this same problem. Go to Home / settings / main settings / initialize. This resets the camera and you will need to reset the date-time.
Mar 12, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot DSC-W50 issues
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Oct 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash. 1)at setup do a initialize. 2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again ) by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Jul 25, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
E:62:10
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
