Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Leaking water My saeco vienna is no longer brewing properly; it started with noticable water pooling under the machine, but it was not coming from the drip tray. Now, it is clear there is an internal problem, as not only has the previous leak continued, but the brew is more like water, and upon completion of the cycle the box that catches the grounds has not only grounds in it but excessive water! The machine has been maintained and cleaned according to saeco recommendations. Any ideas on how to self repair it? Thank you
  • Caffeina Nov 02, 2008
    Whats the best way to get that hole cleaned out? Should we remove the screws holding that panel on?
  • 515 Answers
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Posted on Oct 26, 2008
My Saeco Vienna espresso machine is leaking (rather clean) water on the bottom plate of the machine. What can be the cause and how to overcome it? Thank you for the answer!
if the water is clean -it could be the boiler,if is not exactly clear water -just clean under brew unit motor-when take off brew unit.There can be durty coffee
Aug 30, 2013 | Saeco Vienna Espresso Machine
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Deluxe has water leaking out from somewhere underneath - clear water.
There are so many places to check, but lets check the small chamber under the white plastic valve, which sits behind the brew unit, clean out the chamber of coffee grounds. If that is not the cause then, you will have to open the machine to find the leak.
Feb 17, 2010 | Saeco Vienna De Luxe Espresso Machine
My saeco vienna water is leaking out from somewhere underneath
If it is coffee colored water, then remove the brew unit and look under the white plastic valve in the machine, you will notice a small chamber, clean chamber of coffee grounds and make sure the little discharge to the draintray is also clear. Insert brew unit and check machine.
Jan 27, 2010 | Saeco Vienna De Luxe Espresso Machine
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
165 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
