Question about Sharp AR-5316 Advanced Digital Imager Copier
COPIERS - AR-5316
Pls where do i locate the developer unit and what is carrier?
  • eseagu Oct 22, 2008
    Your Idea helped solve my problem thank you very much
  • Sharp Master
  • 2,794 Answers
The developer unit is inside the cartridge where the toner sits in. usually if you remove the toner hopper out of the copier and remove the top cover off you will see one compartment with toner and one with developer in it. The carrier is the the type of developer to use. All old developer needs to be removed from the machine as well as the mag roller in order to replace it.
Once it is removed the developer is placed evenly into the comparment. The hopper is reinstalled. Then a service mode is performed to calibrate the developed to make sure that the mixture is equal with the toner.
It should be done by a technician because if it isn't done properly, it will result in light copies being produced. The developer may get contaminated and have to be replace if it isn't done in the proper order.
Posted on Oct 21, 2008
My bizhub 350 still says please wait even the fuser unit & lamp is ok. how do i reflash firmware?
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Feb 02, 2017 | Minolta bizhub 350 Black and White Copier
Sharp AR5516 Printer Error F2 40 Pls Provide Solution
Detail:
ATC sensor value abnormality
Cause:
Connector connection trouble
Toner cartridge installation trouble
Sensor breakdown
Check and remedy:
Connect the connector again.
Install the developing unit again.
Replace the developing unit with a normal one.
Thats what the Manual says, your toner is not replenishing , could be your toner motor , or your toner is empty , or your developer sensor
Feb 24, 2015 | Sharp Office Equipment & Supplies
My sharp ara5516 is showing F2 what should i do?
ur developer shd be empty.Pls buy a new developer and fill it in the developer unit
Oct 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
MINOLTA COPIER READING CODE COF32
This code means that the ratio for toner and its carrier is in conflict and that the machine does not recognise percentage ratio its required of it to program.
Most possible cause: Leakage of toner probably through a worn-out bushing in the developer unit .
Solution: Replace the developer and bushings or replace the whole unit.
Feb 23, 2011 | Minolta Office Equipment & Supplies
I have Konica Minolta DI2510 with problem coed C0500 & C0f032
You can try to reset the C0500 error code press the soft initialization on the right side of control panel when the dot appears on the lcd after reboot press the number 3 key the mode will change to the initialization screen choose the selection for trouble reset after reboot the code will be cleared power on and of for basic screen if this dose not work you will need to replace the fuser unit
in regards to your c0f32 code the toner to carrier ratio is wrong this is caused by the wrong developer being used clean out developer unit and put correct developer in the unit
Jan 24, 2011 | Konica Minolta Office Equipment & Supplies
I want the name & address of this mobile number 8002986410. pls sent me the details of my email id pls pls pls pls pls. my email id; deepak15288@gmail.com
Phone Type: unknown Carrier: unknown Address: unknown Location: Framingham, MA Median Income: $91k Median Home Value: $335k ---------------- For the email deepak15288@gmail.com Name: Deepak Sharma Location: New Delhi, India Age: 22
Oct 24, 2010 | Lands Phones
My copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
Aug 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp Photo Copier AR 5316
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Jul 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
