Question about NetGear RangeMax NEXT WN511T (WN511T100NAS) Pre-802.11n Wireless Adapter
Wireless network card & sky broadband wireless router
I have just moved from AOL as my ISP to Sky. Sky provided a Sagem wireless router FOC. It doesnt seem as good as the Netgear router that I used, but I cant seem to get the Netgear router to work with Sky bband. However the Netgear card WN511T that I use in my laptop has found the Sky network but doesn't stay connected long enough for me to access the internet throught the Sky router at all. Any thoughts or suggestions please? Rgds Dave
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 16, 2009
Unable to install belkin n300 to sky wireless router, keeps asking for isp user name and password. sky wont give details
If your ISP requires a login for you to access the Internet, the router has to be able to pass that information to your ISP server, or it will not be able to access those servers. Your ISP should be well aware of this, as many people use routers for their home networks. The customer service section of your ISP should be able to provide you with this information. They would have had to have given this information to you at some time or you would never have been able to get on to the Internet. If you are having issues getting this information from your customer service people then perhaps you need to request a conversation with one of their supervisors. In all my 30 years of working with computers, and almost as many years of accessing the Internet, I have never heard of an ISP that would not provide you with your own login information. Perhaps it is time to change ISP's.
Mar 09, 2011 | Belkin Share N300 Wireless N Router
Tip
Sky Broadband Wireless ADSL Sagem Router Errors with Screendumps
Generally speaking if your @ light on the front of your router is not lit then your telephone line is not enabled for ADSL however you will still be able to goto 192.168.0.1 and check this is an example of the screen display
ADSL LINE FAILURE
LINE NOT
PHYSICALLY
CONNECTED
ERROR : Return Code 100
This also can happen if the twisted pair copper wire that is used to send the signal into your router has been disconnected or there is a short outside your house.
NOTE: That even if BT reconnect and complete a silent line test on your telephone line from your house from the Master Test socket behind your faceplate this doesn't mean that you will have a Broadband Signal from your ISP.
Under normal operation you should see the following screen click show statistics, this line is connected at 3.3MB
on Feb 08, 2010 | Linksys Wireless-G Broadband Router
How can i connect my desktop computer to the internet plz i need someone to help
Currently, the most common way to connect a desktop system to the internet, is by using the network jack to connect to a broadband cable modem or DSL modem. To do either you must have the service from either you cable provider or phone company (For DSL) and have the modem device for the service. Fees run $20 to $50 a month depending on speed you subscribe.
You connect the device to the system using a CAT5 network cable to a RJ45 (8 wire telephone type jack). Some Cable/DSL modems also have USB connection capability for the few systems these days that do not have a built in RJ45 connector To use them, you install the associated software, then connect the USB cable when prompted.
If you don't have Cable/DSL then dial up telephone modem is the next option, this requires a telephone modem that has an RJ11c telephone cord jack connection, most current computers only have a telephone modem as an option, but they can still be bought for around $20 and you will require a dial up internet service (Few remain, one is Netzero in the USA)
Mar 11, 2010 | Computers & Internet
Setting up playstation 3 to wireless broadband asking for wep key not sure what it is
Is there any computer online using the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and networking
Jan 25, 2010 | NetGear WGR614 Wireless Router
When i changed my isp from talktalk to sky broadband my dell 1450 adaptor can not connect even though there is a connection via ethernet cable apparently dell say it is a software problem and want to...
When it says 'Conntected: 100Mbps" on the bottom, all it's saying is that you have a physical connection between your computer and the device it's talking to.
Now one thing you need to double check is that (I assume you have a wireless router) the router or whatever device you have connecting to your ISP modem has the correct network information. For example some ISPs will give you a static IP address that you have to manually add to your router. If TalkTalk does that, and Sky doesn't, make sure your router is automatically obtaining an IP address. This should connect you to your ISP and to the internet. Then your DELL machine should get an IP address from your router and then you should be good to go.
Let me know if you need any further assistance.
Dec 10, 2009 | Dell 1450 (D1450U) Wireless Adapter
I have recently aquired a router and a Wireless PCI Card. Although I am automatically on the internet when I boot up my Computer,I keep getting a message on screen that I have limited or no conectivity....
the limited connectivity means that your router is not connected wirelessly probably because you have not entered the correct passkey, or it's still giving your lan RJ45 network cable the ip address and this is why you are still connected to the net.
If you are on a Netgear modem/router as i suppose you are if it's from sky, you should connect the RJ11 phone line cable into the router leading to a broadband filter, then connect the filter to your phone socket.
There should be no wires between your pc and the router, so take out the wire that is connected to the router (RJ45), which you should have used to set the router up coming from your onboard wired network card.
You will now be connected only via wireless connection, right click on the wireless network icon in your taskbar, click show all connections and then click on your SKY****, whatever it is and then you will need to enter the WPA-PSK security passkey which is with your Sky paperwork or on the router itself.
Sep 10, 2008 | Computers & Internet
Sky Broadband problems
what wireless channel is the router set to? What channel is the 3com set to?
Jul 07, 2008 | Computers & Internet
Blutoohth
Hiya, I have sky broadband too, with a Netgear wireless Router, your second pc needs a wireless card or usb wireless dongle to located wireless networks, once its installed you need the security key for the network, what equipment have you got?
Mar 25, 2008 | Computers & Internet
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
NetGear RangeMax  NEXT WN511T (WN511T100NAS) Pre-802.11n Wireless Adapter Logo
215 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
