Question about Breville SK85XL Nova Cordless Electric Kettle
Plug amp I have a breville illuminator and the fuse has blown. I notice on the plug it states 13amp but the fuse that I took out was 5amp, please could you confirm if it is safe to use a 13amp fuse?
  • Anonymous May 10, 2009
    The kettle does not turn on, presumably due to a blown fuse. However, saddison's post would suggest that the fuse is visible somewhere, but I can't find it. Where should one look for the fuse?
    Welcome Back:
    Visited the website for 2 consecutive days.
Kettle is rated at 3kw that will need 13 amp fuse
Posted on Jan 22, 2016
Where I can replace the net filter in side the kettle?
Posted on Sep 09, 2009
  • 414 Answers
Yes it should be safe to use a 13 amp fuse.
The convention with fuses is up to 720 watts a 3 amp fuse should be used and above 720 watts a 13 amp fuse should be used.
To be precise you need to know the exact wattage of the kettle.
Sometimes maufacturers will fit 5 amp fuses but these are only good for a power rating of 1200 watts maximum (at 240 volts).
So as your kettle is rated at more than 1200 watts it needs a 13 amp fuse.
Hope this is a FixYa.
Posted on Dec 02, 2008
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Feb 04, 2015 | Breville Kitchen Appliances - Others
No illumination
If it works without illumination, it's ok.
Jan 18, 2014 | Breville Kitchen Appliances - Others
No lights or boil
I would test the thermo fuse, power switch, and the AC cord. You will need the proper connectors, crimp tool, and replacement parts.
Jerry G.
Jun 21, 2012 | Brita Breville White Filter Kettle Model...
How do I change or check the fuse on a moulded plug
On the pin side of the plug there is a plastic cover which you lever out, and the fuse usually comes out with it. If you don't have a test meter to check the fuse then either Take a known working fuse from a working appliance and put that in the plug or take the fuse from the plug and put that in a known working appliance oplug and see if it works. In my experience it is rarely the fuse and more likely to be a connection in the kettle base or the thermal cutout in the kettle has fused.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Breville JK155 Electric Kettle
Where can I get a replacement bulb for my breville illuminator kettle
Don't think its a bulb - more like an LED (light emitting diode)
Had to replace
Oct 09, 2009 | Breville Kitchen Appliances - Others
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Sep 15, 2008 | Breville Kitchen Appliances - Others
Can't find a replacement filter
Try Brita or Aqua Optima filters
Aug 21, 2008 | Kitchen Appliances - Others
Illuminator kettle
me too mine has stopped working any one know how to change the bulb? looks like a common fault
Sep 06, 2006 | Breville SK85XL Nova Cordless Electric...
Breville SK85XL Nova Cordless Electric Kettle Logo
541 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Mike Cairns
Mike Cairns
Steve Orr
Level 1 Expert
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
