Question about HP DesignJet 750c plus InkJet Printer
HP Photosmart C7180
Hi
I have a C7180 and keep getting 0xc18a0001 error message, i have been in touch with the out of warranty department of HP and they said throw it out and buy a new one, is there anything i can do?
regards
Doug
  • 4,041 Answers
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error Oxc 18a00001
you may need another print head with that error code message. I would contact HP Total Care (1800-474-6836) and check to see if your printer or print head is in warranty, and it could be replaced.
Error 0xc18a0001
Jan 20, 2016 | HP Photosmart D7260 Printer
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
The printer does an Error code 0xc18a0001 Ink failure and the computer doesn't seem to take the printer on I plug it in and out doesn't matter it's just like if I wouldn't plug in any new...
TO clear the error and return the printer to working order you will need to do an ink purge and reset. The problem is caused by air in the ink cartridges. This can happen if you use refilled cartridges or if you let the ink run to low and try to print something. Here is a link to an article that explains what has happened and how to solve the problem.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 23, 2011 | HP Photosmart C7180 All-In-One InkJet...
I recieve Ink System failure error message with error code 0xc18a0206 on my HP PHOTOSMART C7180 ALL-IN-ONE PRINTER.
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Feb 03, 2011 | HP Photosmart C7180 All-In-One InkJet...
I get a message that the ink system has failed and error message 0xc18a0001. I have turned it on and off again, also tried the suggestion on the HP web site - didn't work.
Please remove off your printer and uninstall the printer. Later reinstall the printer software and then connect the printer. Your harware- printer- will now be detected and installed into the PC. Now check and make a test print, the printer must work right now . If it is still showing an error of the Ink , use the maintenance key for ink chane before you remove the cartridge. Change and check . Good day
Aug 16, 2010 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp c7180 getting message ocx1a002f, any ideas?
Are you sure the error code is not 0xc....
It sounds like your C7180 has an internal error condition and may need to be reset. It may be easier for you to view this solution online from HP support:
An 0x.. error message displays
Dec 21, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP DesignJet 750c plus InkJet Printer Logo
215 people viewed this question
Ben Johnson
