Question about Mitsubishi VS-5043 50" Rear Projection Television
Vs-4007r believe tv suffered power surge,vcr and tv plugged in at same out,vcr was totally dead.tv comes on,screen lights up,has sound.menu screens work,when its in the menu screen(blue background)it has vertical lines.about 2 out of 3 lines are white,then they will slowly to start to zig zag until the whole screen looks mostly white but i can still see the menu letters unaffected behind the distortion
  • 2 more comments
  • txpro1200 Oct 20, 2008
    does the same with menu screen off
    which circuit board???theres about 10 in there
    which board specifically
    i don't care about the vcr,only the as it would appear almost evrything is working
  • 53 Answers
It will require an expert tv tech who can diagnose the fault with hands on testing. Try not to turn on the system again, it might damage it more.
Posted on Oct 20, 2008
    Scholar:
  • 84 Answers
Due to sum short circuit your vcr was ded and tv not working as they
  • rush2aaman
    rush2aaman Oct 20, 2008
    dont try to on your tv again it will damage more
    not only your tv but also your house other appliances
    be ware
    Genius:
  • 1,550 Answers
Sorry to say this you need to change circuit board in your tv . High voltage damaged the circuit board . The symptoms indicates like that .
No picture
If the unit powers at all and you hear some thing from the VCR, and then the unit powers off--problem is in the VCR.
If total dead a fuse is of course possible--If none of these then the TV has a problem in either the High Voltage circuit or the power supply.
To repair or to replace?
May 01, 2012 | Toshiba MV19N2 19 in. TV/VCR Combo
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
Have a Sony Bravia KDL-40v4100 Flat panel, had a bad storm, lightening strike in front of house, now the tv will not turn on.
Now tv turn on?Front LCD screen panel power light indication flashes or totally dead?Yes,than the power board is dead,that the board where power a/c cord plug into it.Take the tv aparts.That the power supply board,require changing.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 27, 2010 | Sony BRAVIA KDL-46V3000 Television
I possibly had a surge on my Element FLX-3711B Tv. It was also connected to a sony surround sound station. The sont was off for a while but reset it self after awhile and now works fine. My TV has not...
Tv now have LED indication power light on the screen panel blinking light or totally dead,no light at all?The power supply board,that the board where the power a/c cord plug into it.That the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 16, 2010 | Element Electronics FLX3711B 37 in. LCD TV
No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Jun 01, 2009 | RCA P61960 61" Rear Projection Television
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
TV seems to be "stuck" in VCR mode after power surge
your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
Sep 25, 2007 | Philips TS2768C 27" TV
Blank screen, power light clicks on and
This sounds like the common problem for this set. A bad connection in the sweep section or a bad flyback and a bad horizontal output transistor. Good Luck.
Aug 08, 2006 | RCA F36444 36" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
