Question about Matsonic MS9158E+ Motherboard
Rgb no signal input, fan on power ok, but still blacscreen,videocard fan ok...
  • 2 more comments
  • Anonymous Nov 18, 2008
    i have a gateway mx3230 the screen broke a got a monitor when i first start the computer up its ok after it gets past the windows loading part it saying no signal rgb i need help asap need to play halo lol thanks drop a line if you can please at kmartinez84@yahoo.com thanks!!!!!
  • Anonymous Feb 04, 2009
    i have tried this but still saying rgb input sigal
  • Anonymous Feb 12, 2009
    i have the exact same proplem yet my old cable worked perfect but it wasnt long enough i got a 10 m cable and now have this problem. I have no broken pins any other ideas?
  • sagumjun Jul 19, 2009
    i found the probem, the mobo is crash......
  • 112 Answers
First check the monitor vga cable. if any pin is broken check it. or try to another monitor to check.
Posted on Jan 23, 2009
Computer no turn on
CHECK WITH A OTHER MONITOR.
CHECK THE CABEL SHOULD SIT TIGHT IN BOTH MONITOR
AND VIDEOCARD.
THE VIDEOCARD SHALL SIT TIGHT SCREWED,AND WELL
SEATED TO THE MOTHERBOARD.
THE VIDEOCARD CAN BE BROOKEN.
Feb 27, 2014 | VIA EPIA VB7001G Motherboard
Rgb no input signal computor stars up on for a few mins then goes blank and a sign saying rgb no input signal
Have you tried to disable the Power settings? For that go to Start, Control Panel, Power Options and in there put everything to Never, click Apply and OK.
If it happens even after that then the video chip is dying and it will have to be replaced - you will need a new video card.
Jun 17, 2011 | Computers & Internet
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I just have a TESTING.... box floating on the screen. Even the menu buttons display nothing. Has this beast finally bit the dust?
Possible reasons for that may be bad cable connection, burnt videocard, or problem in the signal board in the monitor.
So, first check with another monitor if your PC is actually giving a singnal. Then look both ends of the cable for bend pins. They can be easily strighten with thin plyers. You can replace the cable VGA (or DVI) cable to see if it will fix the problem.
If your videocard is OK and the cable is OK, then try to open the monitor. Replace the capacitors on the signal board. Look for blown capacitors on the power board too. Replace if any.
If this cant help, there is major problem with the signal board of the monitor and more measuring is needed. There are buffer elements between the connector and the signal processor and some of them may be faulty. If there are no buffers and the signal goes directly to the processor, entire board should be replaced.
If there are VGA and DVI inputs, you may try the other input with the relevant cable.
Aug 11, 2010 | ViewSonic VA800 17.4" Flat Panel LCD...
Same fan failure issue on 7200
do the fans work? they may need to speed up at certain times for cooling reasons (different signals may need more power. more power, more heat). if the fans aren't working up to par, you may need to clean them or replace them. use canned air.
Oct 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Harddrive
does it beep??
try following:
remove all hardware (RAM, Videocard, disconnect all drives and add-on-cards if possible)
if they PC does not beep when you start up you have either a faulty Mainboard or a defective CPU.
if it beeps put in the RAM first.If you hear different beep you know your RAM is ok. then plug in your videocard. if PC does not start you have a faulty videocard --> replace it.
if you see sth on screen you know so far everything is alright. now plug in the other hardware one piece at a time. BUT REMEBER: always shut off the PC while doing that. better: pull the powerplug....
Dec 26, 2007 | Intel Motherboard
Matsonic MS9158E+ Motherboard Logo
165 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
