Question about Microsoft Office Professional 2007 Full Version for PC
Access 2003 subform won't scroll
I have an access 2003 database with 3 subforms with scroll bars that won't scroll beyond record 82 of 102 available. If you could see what you were doing adding records would still be possible, and checked against the related table which will contain the new record. I have needed input directly into the table so far.
Is there a property that needs to be changed or could this be a system or hardware problem?
Help please
Sue
  • 1 more comment
  • Sue Beatty
    Sue Beatty Oct 22, 2008
    Wouldn't that be a down grade from 2003? I am hoping to get to grips with 2007 soon and need my dbase to be compatible.
    How do I convert to 2000?
    Many thanks for your help
    Sue
  • Sue Beatty
    Sue Beatty Oct 23, 2008
    Ok, I will give your suggestion a go then. Have had a few crashes of the database when trying to alter code for exporting to excel. Wanted to export a report but only have the code for the query.
    The original problem is actually the forms on the switchboard which won't scroll. The crashes made the switchboard form blank and white. A backup was created, but preferred to use a very recent copy prior to the crash.
    Many thanks for your help.
    Sue
  • Sue Beatty
    In the database utilities I have conversion options for 97 and 2002-2003 format. 2000 option is greyed out. Anything I can do about this?
  • Microsoft Master
  • 2,794 Answers
Check microsoft.com/office for any updates.
Convert you database to Acess 2000 and see if the problem goes away.
Posted on Oct 21, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Oct 22, 2008
    It isn't a downgrade.  2003 and 2007 are really just cosmetic features.  In fact most third party applications will only work with 2000 specs.   Especially if you are doing any synching from one database to the other.
    It's located in the tools section under database utilities.  You may find several options for database conversion under there.
  • Tim Babcock
    Tim Babcock Oct 23, 2008
    Your database may already be in 2000 format if it's greyed.  Must have put it in that format by default.
  • Tim Babcock
    Sounds like the database is corrupted.  May have to export data and recreate the form structure.
How do I easily repair corrupt or inaccessible Access database file?
Why to depend on anyone else suggestion. You may download one of the best access recovery tool which will repair your inaccessible access database file. This tool work on windows 10 & below versions also best thing is that free version of this tool will preview all your records after repairing your database. So you may preview your database and can easily review that your data is recovered and to export it you have to use full version. Try this access recovery tool. Access Recovery Tool Repair and Manage MDB or Accdb Database Files
Sep 09, 2015 | Computers & Internet
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Feb 23, 2015 | Microsoft Access 2003 for PC
Module not found in Access 2003
Is it used as a subform in another form? Also does it have any events which are referenced by other forms?
Jul 08, 2009 | Microsoft Computers & Internet
Want to populate a form with data from a table, the Id number is keyed into the form and once it's matches with the Id in the table I want the other fields on the form to be populated with the data from...
Create a Form from the main table with a subform based on the other data you will want populated. You put the fields in the subform that you want populated from the main form. Go to the properties for the subform and select the data tab, In the data tab, select the Link Master Fields and choose the field you want linked. When you type the ID number in the main form, the other firlds you have in hte subform should populate from the data inthe table.
May 14, 2009 | Microsoft Access 2003 for PC
Tabs/sub-form in access 2007 form will not scroll down?
open the form in design view open the properties dialog box by right clicking in the general form area not in the gray area of the detail section. In the properties click on the format tab. In the format tab goto the default view and select continuous form. This should create a virtical scroll bar once a record in the data base.
Dec 30, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Access Program
Sure, Assuming that the field types used offer that option, and most do, but memo may not.
While in the table view mode go to the design mode. Once there look for field length option, and make your change. Be prepared to have existing data truncated to the new max length. You have found out that the datasheet view is the quick and dirty way to update table fields and it uses the properties from the table design.
Jun 21, 2008 | Microsoft Computers & Internet
How to compare a value in a subform with parent form's value in Dcount
Assuming that Process id is an integer, this should do the trick:
DCount("[stageid]", "Process Stages", "[Process id] = " & Me.Parent! [Process id])
Regards -- Joe (Access VBA samples)
May 01, 2008 | Microsoft Office Access 2003 (077-02871)...
Access 2003 HELP PLEASE!
Sharon King:
Did you get this problem solved? I realize it is quite old, but I am willing to help if it is not solved. If it is, I would be interested to know what happened...
smartsolve
Feb 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Restict closing the main form when some controls on the subform are empty
Hi there. I didn't notice this was so old until I had already worked on it for some time. Did you get this the way you want it? If not, I suggest either using a BeforeUpdate control to ensure the condition is met that the subform contain data, or validate the particular field(s) with isnull. Thanks for posting back if you still need help, or otherwise rating FixYa!
Oct 03, 2007 | Microsoft Office Standard for PC
Linking Calculated Totals from subforms to the main form.
Hi Raul from your description it is very unclear what you are trying to do. First we need to know what information is on the first form, second unless you are trying to do a subtotal of all orders in the subform there is no real need for you to create a subform. Now if you are trying to create a subtotal form for all records, you will have to set it up in the record source of that subform with group by: 1. Right click on an empty space on the subform 2. Click on properties 3. Choose your table(or query) which is the record source of the main form. 4. Select Payment and items(or what ever you are trying to calculate). 5. Press the group by button 6. In totals instead of group by choose sum. 7. Exit and save 8. Now when you will select the control source you will see "sumofpayment" etc... just select them for each textbox. 9. To create the third text box you will have to use the Expression builder and just do [textbox1]-[textbox2] * for some reason the nz function does not work in this case. I hope that helped you I will be able to give you a better answer if you give me more details... Let me know what happend Good luck Daniel
Sep 02, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
271 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
