Question about Dell Dimension 8100 PC Desktop
Tv screen attatchment
I am looking to attatch a tv screen to my computer so as people can watch videos etc via the computer. which output point do i use from the hard drive
    Problem Solver:
  • 16 Answers
As you have not mentioned the type of TV you want to connect I assume you are having the normal TV and not a High Definition TV.
First check the back of your computer . If there is a small yellow (round) port which is the TV out port(It is similar to the ones found on a DVD player. If you have TV out port in your computer then you can connect your PC to your TV. Or you can buy a video card for your computer which has a tv output port.
Posted on Oct 20, 2008
    Genius:
  • Dell Master
  • 1,252 Answers
YOU HAVE TO CHECK YOUR DISPLAY CARD FOR THIS WHETHER IT HAS THE OPTION TO CONNECT TO TV, or
you can use hard disk player available in the market, to connect to tv or monitor for watching movies etc.
How do I attatch my DVD player to my tv?
Video/audio outputs of dvd to corresponding inputs on tv
Sep 16, 2017 | Televison & Video
Hey iJust bought a 42 inch Phillips lcd tv And i am trying to attatch my lToshiba E100 Satllite lap top to it via the HDMI ports on both the tv and laptop but nothing is happening
When you have the tv connected and both on, Switch the TV to the HDMI feed then press the [FN] key and hold and start pressing the [F4] key counting to 10 between presses. You have to tell the computer bios to activate the external port and send video signal to that port.
Mar 14, 2011 | Computers & Internet
I dont seem to have an audio out port on my LG tv to attatch a sound bar, what can I do?
on the TV, there should be audio / video output with RCA plugs. usually behind the TV, exactly beside / parallel with DVD and Audio Video Input
Aug 16, 2010 | LG Televison & Video
I have a panasonic mv-gs15 camcorder an i have no accessories for it what do i need to be able to attatch the camcorder to tv so i can watch on tv also how can i transfer recordings to dvd can i attach...
tv should be easy just buy av cable (red yellow white end ) for your camcorder DV(look for little squarehole with maybe four pin ) connection.. computer should be dv to pc firewire..
May 15, 2010 | Video Cameras
My screen shows blank.how can i retrieve contacts through PC
you need [mymobiler]programme .install on computer,attatch phone via usb and you can see your phone and data on computer..
Apr 18, 2010 | T-Mobile Wing™ Smartphone
How to setup the s-video config to display on lcd tv Sahara dn610
This answer is not specific to Dell, sort of a general answer but should work on your system.
Shut down your computer and make the connections between your computers s-video out and the tv s-video input. Leave your monitor attatched or you won't see anything. Also turn on the tv so that it's working.
Start the computer up and let if finish doing it's startup, it may find the connection on it's own, but probably not. Once the computer has started up and it has nothing else to startup, then right click on thre screen, bring up your display, go into the advanced tab, and from here you will have to do some hunting, what you are looking for is the output section, since from here you will have to tell the computer what is on the s-video output, ie crt, plasma, lcd. Once you have that you should be good to go.
I don't know where it is in your computer software but it should be in there someplace.
Hope this helps and that you get it done.
Mar 15, 2010 | Dell Dimension 8300 PC Desktop
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Overload wihout any attatched components
If you don't have anything attatched to the unit and it display's "overload" Your unit needs to be serviced. Output transistors are shorted. Get an estimate and weigh the cost of repair vs. replacement. Hope this helps
May 30, 2009 | Audio Players & Recorders
Tv connections
Depending on the model of video card you have, it would be either the VGA or the DVI connector. Many new cards have one of each or 2 of either VGA or DVI.
Many newer LCD monitors can to plugged into either connector, as they have connections for both. There are adapters that will allow VGA to be plugged into DVI as well.
If you computer does not have multiple outputs, you can only plug in one monitor, however.
Oct 18, 2008 | Dell Dimension 8100 PC Desktop
Dell Dimension 8100 PC Desktop Logo
333 people viewed this question
Alun Cox
