Question about Fuji FinePix A345 Digital Camera
Problem hi my camera seems to be stuck on standby it won't move to camera setting you can move it manually but on the screen it still shows standby. i have tried removing the batteries but still no change sandra
    Sergeant:
    Novelist:
  • 196 Answers
Replace the battery as it is old so the power is used.or if it is new check whether if it is of any local company batterey.or any reputed battery such as duracell.
thanks.
Posted on Nov 05, 2008
HL32V86 Hisense 32' stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
Jan 03, 2015 | Hisense Televison & Video
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
LENS OPENING BUT NOT SHUTTING
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Jul 04, 2011 | Olympus Mju 725 SW Digital Camera
Lens is stuck (halfway out) and screen shows "lens error" and won't do anything
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 30, 2011 | Nikon S8100 Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
Everything works except for mp3 when i plug it in. doesnt even say aux on screen
Just figured this out !
1) You have to be in 'Standby' mode - press (SRC) until it shows standby.
2). Press and hold 'Menu' button.
3). Using the joystick - move it left or right until it shows 'AUX' 'OFF'.
4). Move joystick up or down until it shows 'AUX ON1'.
It should now work ! - This is on P.22 of the manual - but it actually starts on page 19 where it describes 'Standby' mode.
Aug 03, 2010 | Kenwood KDC-MP205 CD Player
I changed the batteries and continued to take photos when i noticed that the screen was flashing on and off and then going to standby mode. tried resetting back to default but screen still flashes. flash...
Hi Bill,
You are not using this flash like a sub-machine gun, right?
Is your reachargeable batteries older than 15 months?
Try this:
Set to low power on flash, set flash to manual.
Remove flash from hotshoe.
Fire the flash by pushing the flash button for 3 mins, same problem(s)?
atdlee@netzero.com
Jan 17, 2010 | Nikon Speedlight SB-600 TTL Flash
Stuck on movie standby
The ribbon cable for the top switches has come loose.Undo the four screws holding the LCD screen (two are special--I used the corner of a small flat screwdiver), then gently prise the camera apart and try not to dissconnect the ribbon cable for the menu buttons --it's a pain to get back on again.
Gently ease the ribbon cable for the top switches further into the socket and all shout be well---if it is hard to move flip open the black locking flap on the socket
Jan 05, 2008 | Fuji FinePix F20 Digital Camera
Standby problems
Yeah,
Press all the buttons at the same time, threaten to through it in the toilet, then give it a couple of agressive taps.
It works.
Really.
Jul 11, 2007 | Samsung Digimax A400 Digital Camera
Fuji FinePix A345 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
