Question about Philips DCP855/37 Portable DVD Player
Philips DCP750 My Philips DCP750 Portable DVD will not charge. The green charging light just flashed every 15 secs. I suspect the battery is faulty but would appreciate if anyone can verify that idea.
  • Anonymous Apr 03, 2009
    same problem with dcp850. The battery is internal so its hard to replace even if you can get your hands on a replacement.
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips DCP750/37 shows "wrong region"
Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Posted on Dec 29, 2008
SOURCE: DVD DCP750
The rechargeable battery inside the unit is made by a company called Yuku out of Quongdong, China. It is a 3.7V double layer battery with (3) soldered connections. I have not found a replacement yet, but am still looking.
Even though the unit is new, it does not mean the battery has not gone beyond its expiration date, for chargability. Hence new unit, old battery.
Miccey.
Posted on Jan 20, 2009
SOURCE: i have the philips dcp750 portable dvd player
i have a durabrand portable dvd player model.pdv-709 and it will only play cds noy dvds
Posted on May 19, 2009
SOURCE: my philips dcp850 portable dvd play battery won't
have you had this problem fixed?
Posted on Aug 09, 2010
SOURCE: Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Posted on Jan 23, 2011
Philips DCP855/37 Portable DVD Player...when I try to charge up the lithium battery it does not charge. The directions say to turn off the power and the green charge light will turn on. When I plug it in...
Batteries in these things don't last very much; it is most likely a bad battery. Replace the battery with a new one and your problem should be solved.
Aug 03, 2008 | Philips Televison & Video
I have a MDP845 Magnavox portable dvd players that looks to be charging but the light flashes orange and green and is not charging. The manual says that it will flash orange when charging and when fully...
Likely the battery but it could also be the charger---if someone tests the voltage coming out of the charger with a volt meter it will eliminate that as the cause
Mar 24, 2012 | Televison & Video
How do i know when the dvd is charging?
When you first plug it in, the green led should flash for a few seconds. It will then go on solid green while charging. The green led turns off after it thinks the battery is fully charged. Not sure what it does with a defective battery but this is the basic charge sequence.
Apr 07, 2010 | Venturer PVS8380 Player
Mar 13, 2010 | Philips Televison & Video
Does not switch on and there is no orange chg.light or green ligh
Your' battery may be bad, have gotten disconnected, or the battery is dead, and the charger is bad.
Dec 29, 2008 | Sony DVP-FX810 Portable DVD Player
Portable DVD Player will not power up
This player should be charged up until the green light goes out to be fully charged. I usually leave them on over night.
Glenn
Mar 16, 2008 | Philips DCP855/37 Portable DVD Player
Philips DCP855/37 Portable DVD Player Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
