Question about Samsung DVD-P142 DVD Player
Disk stuck cannot open or close..disk stuck
  • Anonymous Apr 19, 2009
    my disk is stuck im my laptop how do i get it out?
Sony cfd 646 - cannot open disk tray
Some have a tiny hole in the tray front to manually release it/push the tray open.
Dec 20, 2016 | Sony Televison & Video
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
Optical drive tray is open, can't close - disk is stuck inside my notebook
Power it down and if you look very carefully, near the eject button is a hole.Insert a straightened paper clip and the drawer will open. Unless it is a Mac.
Nov 09, 2013 | Computers & Internet
Dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Dec 02, 2009 | Philips Televison & Video
Disk drive door stuck, won't close.
if your warranty is already voided then you could try openning up your xbox and then openning up your dvd drive and just see what its getting jammed up against
Jul 29, 2009 | Microsoft Xbox 360 Console
The disk drive wont shut on my xbox360
Your disk drive shutdown, you will have to open up the xbox, unplug the disk drive then plug it back in.
Jul 16, 2009 | Microsoft Xbox 360 Console
I close the disk tray and immediately opens again and stays open
Hello,Do you have the original face place on? Some after markets will cause the open tray button to stick. Next check the button to see if it moves freely, when doing this, also try feeling the button if it bottoms out, check for any debris behind the button, If these don't change the situtation, then there is a sensor on the tray to tell if it's opened or closed, the sensor is either malfunctioning or something could be stuck to the bottom side of the tray from preventing the disk to load, The last thing would be to look into is there a forgien object stuck in your tray area like a piece of papper or plastic, I hope this will help resolve your problem, we look forward to hearing back from you and please have a nice day, Thanks
Jan 14, 2009 | Microsoft Xbox 360 Console
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
Samsung DVD-P142 DVD Player Logo
Henry  Thomas
Henry Thomas
