No sound i have acerpower F1(intel inside).the operating window is XP. one day i boot(formatted) my computer with window xp. after that there is no sound from my computer.the volume level,the media level all are fine except there is no sound heared from my PC.my audio driver is realtek. please help me to hear sound from my PC.thank You!!!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
When you reformated your computer, you got rid of all your drivers which Windows XP will not put on. You need your motherboard chipset driver disc.
Realtek Here is the link where you can find your driver.
If you can tell me the model of your realtek driver, I can help you more.
Posted on Oct 22, 2008
I have Intel 845 series motherboard & I want to format my PC but when I put xp cd inside & restarts & press enter the boot doesn't start now how could i format ?
You have to change the BIOS settings to boot from your CD drive. It must have been set to boot from harddisk.
To do this you have to change the primary boot device from Harddisk to CD drive. When you restart your computer press DEL or F12 or TAB or F1(any one...Depends on your BIOS see manual or try all) to bring bios. In bios go to boot device priority and set the CD drive to boot first.
Restart your computer, it will boot from CD drive and XP setup will start.
Hope this will help...cheers:)
Sep 25, 2010 | Intel 845GE Motherboard
There is only one OS, but during booting it shows three
Delete the OS Command line inside the MSConfig indow by clicking start - run -type msconfig then press enter. On the MS config window click on the boot.ini tab then you will see the command line inside the text box. Leave the first command line from [Boot Loader] till the end of the command line of your Default Operating system.
Example:
(Leave this lines)
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
(Till here!)
(Delete this line)
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Viz XP Example line Professional" /fastdetect (up to here)
any other command line that says Viz XP -- you may delete it. Click apply button then Restart the computer afterwards and this should fix the issue.
Should you have any other questions just please leave a comment.
Cheers~
Jun 28, 2010 | Intel D845GVSR Motherboard
Hi there, my problem is ,my windows xp can't startup. i thought my OS has problem, then i try to reformat it (reinstall winxp). the format process fail to complete as well. I try to format same HDD to...
There are a few things you can try . First , try this : the computer is off . Turn it on and Press F1 key repeatedly or whichever key applies to your computer that enables you to access your BIOS settings . Then , using the arrows you will select boot options or boot settings . Then , you want to arrange the boot order device sequence so the CD is first. Some computers display a boot device options when you first and computer on by pressing a special key, like ESC or F12. You want the computer to boot from the CD ROM with your XP disk in the drive. This should allow you to properly format the HDD and install XP. If that doesn't work , check your BIOS settings and select the default configuration , then be sure to exit using the exit dialogue box and select exit saving changes and then yes when prompted . Then, do the device boot options thing one more time with the CD as the first boot device .
Apr 27, 2010 | Microsoft Windows XP Professional
FORMATTING WITH PEN DRIVE
Your motherboard basically has to compatible with a boot from usb. On power up, press either f1, f2, esc, or delete to bring up the bios. Then slide over to boot options or boot order. Put Boot from USB as your first priority.
Apr 04, 2010 | Computers & Internet
AcerPower F1 desktop boots fine after about 10
More likely it's from overheating; if it would be from the power supply ithe shutdown would be more random.
But it could also be a malware infection - especially if it happens EXACTLY after the same amount of time . Check what processes are active just before shutdown .
Nov 09, 2009 | AcerPower F1 PC Desktop
Win xp instalation
Make a windows 98 startup disk by downloading it from here http://ru.dod.net/ben/boot98.exe . Once you haver done that turn off the acerpower insert the disk and turn it on (make sure its set to boot from floppy disks in bios setup) Choose the option start computer with cd rom support. Now after about 1 minute youy should see a:\. Type in a:\fdisk and then choose yes and then create a partiossion using the prompts given . Once you have done that and its finished it should say you must restart this computer so restart it. Then boot from the floppy disk again and when it coms to a: type FORMAT C: and then press y. Once its done take the floppy disk put and restart your computer with the windows xp disk in and it should start installling windows xp.
Jul 08, 2008 | AcerPower Sn PC Desktop
Operating system is not found!
Try checking the boot sequence of your computer. Turn on the computer and press Del or F1 before the POST. You will see there an option for Boot Sequence. Make sure that the 1st Boot is set to your hard disk.
May 18, 2008 | Microsoft Windows XP Professional With...
Formating the Pc
Is the Hard Drive NEW and unused ?
If YES, XP should install no problem.
If NO,
Format with DOS boot disk and then install.
Mar 14, 2008 | Computers & Internet
Enter BIOS on boot
According to the intel manual the key is F2
"The BIOS Setup program can be used to view and change the BIOS settings for the computer. The
BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST)
memory test begins and before the operating system boot begins."
That is from the manual for the board, instead of reinstalling Windows you may as well just change the product key on one of the installations to your other copy.
Mar 07, 2008 | Intel D850MV Motherboard
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
