Question about Mesh 80mm Aluminum Fan Filter Fan Kit
My CPU is making lot of noise especially when I'm using programs like Adobe reader
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Posted on Oct 21, 2008
My cpu is making lot of noise pl. fix it.
thanks
vivek
Posted on Dec 14, 2008
How to split screen on Windows 8.1 using one app?
I guess you need to open the one app two times. Then carry out the split screen procedure. See link for clear details off this
How to Use Split Screen Mode in Windows 8 1
Sep 29, 2014 | HP Computers & Internet
Internet explorer hangs when opening a pdf file using dragon
The browser addon called adobe pdf reader is causing this problem,
Goto Tools Manage addons and you will find the Adobe pdf reader, I suggust you disable this reader,
Now a trick that works is to restart the browser then goto Adobe website at http://get.adobe.com/uk/reader/.
You may have to goto add and remove programs from the control panel and remove adobe reade and reboot then try the link above.
Regards
GeWiz.
Oct 22, 2009 | RTO Nuance Dragon Naturally Speaking...
My system has adobe 9.1 but when i want to open some pdf it still says version 8 or 9 required
It sounds like you may have more than one version of Adobe Reader and/or Adobe Acrobat installed on your computer (not recommended) and the system is probably confused about which one to use when opening a .pdf document.
Right-click any .pdf file located on your system, and then, click Open With and then click Choose Default Program.
In the window that opens, select the program that you want your system to use when you open a .pdf file (in your case it should be Adobe Reader 9.1). It *should* be listed under the Recommended Programs section but if it is not then you will need to use the Browse button in order to located Adobe Reader on your system. If the correct program is already selected, then I suggest you unselect it and then reselect it. Make sure the "Always use the selected program to open this kind of file" check-box is checked. Then hit the OK button.
As stated earlier, it is not recommended (and not supported) for you to have more than one version of Adobe Reader installed at a time. You should do the following if the above solution does not work for you:
In Windows, go to Start Button > Control Panel > Programs > Uninstall a program
Look through the list of your installed programs for Adobe Acrobat and/or Adobe Reader. Uninstall them both (if you have more than one installed) then download and run the Microsoft Installer Cleanup Utility to remove all traces of Acrobat Reader.
Now re-install your latest version of Acrobat Reader only.
Oct 04, 2009 | Adobe Computers & Internet
I'm using Adobe Reader 9 with Windows XP. When I
You may need to remove the Adobe 9 program, download the program again (there was a recent upgrade), and reinstall it. That should override any previous settings.
Sep 26, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
I've tried downloaded updated versions of adobe reader; have done so, but there are older versions which now interfere. I'm unable to open any version at this time. Can you help?
The only recommendation i could make for you is just uninstall the previous versions then re-install the one version you would like to use...That's the only solution I know so far...
Jul 23, 2008 | Adobe Acrobat 7.0 for PC
Adoberdr 7
I would uninstall that and use FoxIt Reader....much faster. I switched a couple weeks ago, no issues yet. It is a 5MB install compared to adobes 50MB....just to read pdfs.
You can get it here.
Feb 01, 2008 | Microsoft Windows XP Home Edition
Viewing pdf files on internet
Uninstall Adobe Reader, shut down completely for at least 30 seconds, and then restart.
This releases "Locked files" for deletion.
Then do a search for "Adobe", in 'all files and folders' - search with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those files found.
You should do this search and delete whenever you un-install any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
BEFORE RE-INSTALLING Printmaster
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling. Go to the Adobe website and install the newest Adobe Reader 8.1 program.
http://www.adobe.com/products/acrobat/readstep2.html
Dec 07, 2007 | Adobe Acrobat 6.0 Professional for PC
Adobe Reader
This is a nice little FREE utility you can try. Install Microsoft "Windows Installer CleanUp Utility" http://support.microsoft.com/kb/290301/en-us
If you find (PROGRAM NAME) listed just hit the delete button.
This will take care of the MSI problem.
Then do the normal Uninstall.
Uninstall Adobe Reader, do a search for all "Adobe" files and delete them. Go to the Adobe website and install the newest Adobe Reader 8.1 program.
CLEAN INSTALL needed here.
This time after the Uninstall, shut down completely for at least 30 seconds, and then restart.
Then do a search for 'all files and folders' - search for both 'Adobe' and then '7.0', with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those related files found.
You should do this search and delete whenever you Uninstall any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when re-installing or updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
BEFORE RE-INSTALLING Adobe 8.1 it's the NEW VERSION!
Nov 02, 2007 | Adobe Acrobat 7.0 for PC
Damaged adobe reader 8 damaged
if you get this error message when you try to open a particular file. the problem could probably be in the .pdf file and not the software. if this is not the case, uninstall adobe reader completely and reinstall it. if this docent work. download the latest version of adobe reader from the adobe site and try installing it again.
Jun 10, 2007 | Adobe FirstWare Recover Pro 2004...
Adobe acrobat reader is not opening...
if you have the original install disk for adobe acrobat reader the uninstall the program then power down then re-install the program
May 22, 2007 | Adobe PageMaker V7.0.2 for PC
Computers & Internet Logo
741 people viewed this question
Top Mesh Computers & Internet Experts
Sandeep Kumar
steve s
steve s
Glyn
Are you a Mesh Computer and Internet Expert? Answer questions, earn points and help others
