Question about Intel D915GLVG Motherboard
Please Help !
  • 849 Answers
The fan of your prcessor gone dried, it need oiling or replaced.
Posted on Oct 20, 2008
Shutdown after 15 minutes
If it seems to boot and run normal for the first 10 to 15 minutes then powers off it is probably a thermal issue. If this is the case, most of the time you will have to wait 5 or 10 minutes before it will turn back on. ( Not always depending on the part, some cool very quickly.)
The first thing you should check is the fan on the cpu. If it is running normally make sure that the heat sink is seated securely. Also make sure any other fans are running correctly.
Another possibility for a heat problem is airflow in and around the computer case. Make sure that all the vents have a couple of inches of open space around them to draw air in and out or the case. If the computer is in a cabinet make sure that adequate cool air can get to it and that the heat can get out.
Jan 14, 2014 | ASUS P5GZ-MX Motherboard
RAM Problem in intel D915GLVG mainboard
Most likely the pc400 hynix is incompatible with the mother board, or with the memory you are leaving in place. Try using just the pc400 sticks, if you still get system beeps then you are using incompatible memory. You should go to centon, or other memory manufactures wesbsite and look up what is compatible with the mother board and get that memory for the system. My bet is going to be pc3200 memory.
Hope this helps
Jan 25, 2012 | Intel D915GLVG Motherboard
I need PCI device driver
Hi, you can download the drivers needed here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D915GLVG%22
The drivers needs to be unziped before installation.
Or use windows update.
Hope this will help you.
Aug 16, 2011 | Intel D915GLVG Motherboard
For intel D915GLVG motherboard can i get any good graphics card to play games
Dear rahil bakshi,
please refer the user manual for supporting frequency.if you haven't the users manual please visit this link and download the manual for much information about supporting cards.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=15194&ProdId=2062&lang=eng&OSVersion=OS%20Independent&DownloadType=Documentation
thanks
Jun 18, 2011 | Intel D915GLVG Motherboard
Sir is ram of intel d915glvg motherboard is sd of ddr
That motherboard takes DDR PC2700 or PC3200.
Check out this link:
http://www.crucial.com/store/listparts.aspx?model=D915GLVG
Thanks for using Fixya.
Feb 09, 2011 | Intel D915GLVG Motherboard
I have intel motherboard D915GLVG . i want the link for Ubuntu drivers for LAN connection
this might help
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+915+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D915GLVG
Mar 19, 2010 | Intel D915GLVG Motherboard
After unit is on several minutes, sound turns to static, crackling noise. Any ideas
I had this same problem, check the power transistors attached to the heat sink near the large caps, they tend to get cold solder joints after lots of heating and cooling. 15 minutes and good soldering iron will probably make a huge difference. I added extra cooling fins to mine to help dissipate the heat. hopefully wont go bad real soon again. Also check the large caps while your in there, maybe a good time.
Dec 02, 2009 | RCA RT2500 System
Motherboard driver problem
Please download intel chipset identification utility by http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=861&DwnldID=13799 and then run it .
It will tell u the exact chipset of your board and then u can download the drivers.
Feb 20, 2009 | Intel D915GLVG Motherboard
D915GLVG drivers
YES U CAN GET GO TO WEBSITE JISKA TUMHARA LAPTOP YA PC HOO DN U CAN DOWNLOAD UR DRIVERS ,,FR DT U NEED TO KNOW UR CPU MODAL IF U HAV ANY PROBLEM SEND ME MY MAIL ID SWATI27M@GMAIL.COM
About upgrade my graphics memory
Your Intel D915GLVG has a integrated PCIExpress built into the board. Your system memory is shared with the built in video card. This board's memory can handel up to 4GB of system memory which up to 512MB can be shared from your system memory. If you wanted to disable the integrated 915GL Express Chipset with Intel® Graphics Media Accelerator 900. You would be left with two PCI slots. Running a PCI video card is slower than a AGP card & two notches down from a PCIExpress card.
So in order for you to acheave what you want your going to have to increase your system memory. If you still have your manual the specifactions for your memory is on Pg. 9.
The link below is a list of supported memory from Intel.
http://support.intel.com/support/motherboards/desktop/d915glvg/sb/CS-027048.htm
If you no longer have your manual you download it from this link:
http://download.intel.com/support/motherboards/desktop/d915glvg/sb/c996091_en.pdf
Though you can check aound. I can suggest this mamory which will give you 2GB dual matched memory that is within your boards specifications. Listed at this link. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1075233&CatId=1352
You will still have two memory slots free to upgrade to a total of 4Gb at a later date. So please do not disable your current video card. Please use your manual when installing memory. Two Dimms go into certain slots on the D915GLVG board.
Enjoy!
please vote....
Feb 07, 2008 | Computers & Internet
Intel D915GLVG Motherboard Logo
48 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
