Question about Samsung RS2534 Side by Side Refrigerator
Freeing food in refrigerator, even vegetables in vegetable tray
In my refrigerator, even at maximum temperature, everything is getting freezed making all tomatoes, cucumbers ,milk to ice.
Hi amjad from italy.
Posted on Oct 20, 2008
    Scholar:
  • 57 Answers
You have 2 dials in the refrigerator. One is the thermostat setting the cold temp in the freezer, the other is a damper that allows cold air from the freezer to the refrigerator. Set the thermostat to the middle then try closing down the damper, most say colder or warmer refrigerator. If the damper is closed and your refrigerator is still freezing, then I would guess that the thermostat is bad. A thermostat runs about 40 to 60 dollars wholesale. Retale should be about double.
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Vegetable compart freezes the vegetables
You probably have your compartment set to meat and not produce. Adjust the setting on the tray, or get the food further away from the air return ducts.
Jan 23, 2012 | Kenmore Side by Side Refrigerator
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
PSS25S side by side is freezing vegetables. We
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 12, 2009 | GE Profile¿ Arctica® Energy...
Vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
May 03, 2009 | Refrigerators
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
386 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
