hi..i forgot d password of my nokia 5310 micro SD memory card... i recently updated the new software version and since then it has got locked... pls tel me the solution as soon as possible as i dont remember the password assigned to it
how can i reset my memory card code in my nokia 5310
Same Problem
May 16, 2009
-   hey! i have a memory card and i want the password off and i cant rember and i cant use it in other phones and i have a new phone i jus want to get rid of the password so i can use it the memory ................x-   miss_efron15
May 02, 2009
-   Hi I have forgotten the my 5310 Xpress music password can i recover it or break it
-   ive got a nokia 5310 and the memory card has got a password on that i cant remember. dont care about the data, just want to be able to use it again.
-   Guest
Apr 24, 2009
-   hi..i forgot d password of my nokia 5310 micro SD memory card... i recently updated the new software version and since then it has got locked... pls tel me the solution as soon as possible as i dont remember the password assigned to it -   altaf_ae
hi Default code for Nokias is 12345. This will work if you did not change access code. If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here. After installing file manager check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 5310. Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory: Take the SIM card out. Make sure your phone battery is fully charged. Press* 3 sendat the same time and turn the phone on. Keep this two buttons pressed until the reset screen appears. Wait some time to reset. Switch phone back on. By Mr.GINKO plz do rate this post
locked... pls tel me the solution as soon as possible. I have nothing entered a password.. thnx..
I forgot d password of my nokia 5310 micro SD memory card... i recently
