Question about Toshiba Satellite A60 Notebook
Intermittent power up
I have toshiba sattelite A60 model and it was working perfectly until I tried to upgrade the memory to 1GB. I bought the memory from local shops and when I inserted the card and restart my computer it did not turn on. I tried again but my computer didnot power on. I removed the memory and started my computer again but very hard now to power on. My computer will power on after several tries. Did my trying to upgrade the memory affected my laptop. Did it damage my Motherboard? What do you think the problem is? Please help. Thank you
  • 2 more comments
  • vhizo Oct 20, 2008
    probably at first i did not lock both so I tried again locking it firmly. could this be the cause? If it is, then what is the best thing I should do?
    Thank you pankaj_dic for your reply, I appreciate it. my laptop has 512 RAM and it is built-in and i am trying only to upgrade it to 1G by adding another 512 to its upgrade slot.
    To add more information about my laptop's intermittent power up, when I press the power ON switch, the blue light is lit and I can hear the HDD rotates but stops. so I press and hold the power switch to restart the computer until such time the HDD works and the computer power up.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    yes..quite a bit it would..did you replace two sticks with one, by chance?
    Master:
  • 538 Answers
Hmm..that power up sequence sounds like a battery state issue..try it with only the ac power included, with battery removed.
Posted on Oct 20, 2008
    Genius:
  • Toshiba Master
  • 1,250 Answers
Take out your battery then put it again,
put the original RAM, your laptop is not supporting this RAM
Toshiba sattelite a200 won't turn on
Try removing the battery. It might be faulty and shorting the adapter.
Oct 31, 2008 | Toshiba Satellite A60 Notebook
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Memory for toshiba A65-S126
Its in the middle of the laptop at the back side..you have to go through the manual for changing the ram.. there will be 2 locks ,you just have to press and pull it up.
Jul 21, 2008 | Toshiba Satellite A65-S126 Notebook
Hi, I have a toshiba sattelite a55-s106 laptop that I recently upgraded from xp to vista home prem. After that I decide to add more ram. The system is supposed to be able to handle 2gb of ram max. If I...
Vista will not be the culprit here. The beep most likely meens that thee is a problem with the memory stick itself, especially if it boots normally when you take it out again. Motherboards are mostly designed to take identical sticks of RAM in pairs (Same brand, same model, same amount of memory) and sometimes, you will find that different manufacturer's RAM will not work in some systems.
Check to see if the RAM stick you are putting in is the same brand/model as the one already in. Also check to make sure it has the same amount of RAM on it. It could also be defective.
I hope that helps
Jul 09, 2008 | Toshiba Computers & Internet
Screen is blank
ram may not be compatble what speed u buy and what brand sodim ram did u buy hit reset button on botton for 20 sec take batery out and new ram to get old to work ok
Jan 23, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba a60 wont work with the interactive smartboard
YOU DONT HAVE ENOUGH RAM POWER WITH THIS COMPUTER MAX OUT THE MEMORY WHEN YOU UPGRADE
TO ATLEAST A GIG OR 512MB AT THE LEAST
Jan 18, 2008 | Toshiba Satellite A60 Notebook
Toshiba A60, Won't Load Windows XP.
did you try with diferent memory ram may be that is your problem because the memory can not prosses all the data to download windows
Jan 01, 2008 | Toshiba Satellite A60 Notebook
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Memory/RAM
you are probably not using the correct type of memory, if you just bought a 1 gb stick, Laptops are pretty picky about what memory they use, check the Kingston Memory configurator to find out the max installable mem and which mem is correct to use.  http://www.kingston.com/ukroot/default.asp  use the Memory search feature on the right of the page to get you started
Toshiba satellite is a seperate section in the configurator, so choose that line to get more choices
Oct 16, 2007 | Toshiba Satellite A60 Notebook
Upgrading RAM and Batteries
For batteries, my advice would be to stick with the brand of the unit (Toshiba, in this case). Toshiba lists a 12 cell battery on their website under the "laptop accessories" section of www.toshiba.com. For the A60, the part number is listed as PA3382U-1BRS and costs $152.99. You can search google for another place to buy (perhaps where you bought the laptop) but be careful that you don't get a generic in place of the original (OEM). With memory, Kingston and PNY are the aftermarket leaders and you can't go wrong with either. Kingston's website lists a whole slew of specific A60 models. Some with 256MB on board (not removable) and some with 512MB on board. So, a 512MB chip may give you 768MB or 1024MB depending on the exact model. Max memory seems to be either 1.25GB or 1.5GB depending on how much is onboard (and not removable). Installation is usually easy on any laptop and typically requires only a small screw driver to remove the memory cover on the bottom. The owners manual for the laptop likely gives the steps to add memory.
Sep 02, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
