Coming up loading error will it load with only one 1gb pc3200 ddr dimm
  • johntoulson Oct 20, 2008
    as stated new board + memory dimm + cpu not used will not load driver disc
    all i require to no should system boot with only one memory module when as stated previously about dual channel memory technology should i purchase another module?
  • 19,396 Answers
If it load only with one of the two modules, than one of the modules is faulty. A faulty RAM module sometimes may only work along, you get this when you have problems related to memory random access on one module.
1GB RAM is not expensive nowadays, get a pair of new modules, that is what would have been done in a workshop.
Regards
Posted on Oct 22, 2008
    Genius:
  • 1,011 Answers
Dear,
explain it in detail as asked by my fellows. so that we can pin point the fault and cure it for u
regards,
Posted on Oct 20, 2008
  • SALMAN NASEER Oct 20, 2008
    does it mean that u want to use two RAMS but it allowing only one to access/boot..not booting with other..
    or the problem is different...
    regards,
    Master:
  • 763 Answers
Sir can you pls clarify and state the exact problem so that we can help you better.
CHARCOIS
  • Charris Suaybaguio
    Charris Suaybaguio Oct 20, 2008
    if your computer is running with one memory and it works with no problems then just use one memory. if your computer needs to have more memory because its lacking of it then add one. just be sure that the previous memory is the same as the memory that youll be going to buy. because if your going to buy a new memory with high specs or different than the older one it may have a conflict. hope that helps!
    thank you for using fixya
    CHARCOIS
  • 53 Answers
Can you please provide more specific information? You can try re inserting the card into the slot. If there are two slots, try interchanging it.
    Sergeant:
  • 306 Answers
The question is not much clear.. u need to tell the brand, and explain the problem briefly!! ur ques is not completed!!
  • AbdulRahiman S Oct 20, 2008
    if u get the loading error in the startup of your PC then try this..
    Remove all the cables connected to motherboard means sata cable, ide cable floppy cable and then start the computer and then go to the bios options and afterwards connected devices one by one and finally try to find what ha been causing the problem. at times the problem may not be on ur motherboard but maybe one of your devices.
    Scholar:
  • 84 Answers
Plz. explain your problem in detail
  • 4 more comments
  • rush2aaman
    rush2aaman Oct 20, 2008
    check the link:
    http://en.wikipedia.org/wiki/DDR_SDRAM
    i hope that the link may helpful for you
  • rush2aaman
    oh! what you want to say
    check them
  • rush2aaman
    discribe about your main bord ?
  • rush2aaman
    which bord you are using?
  • rush2aaman
    you need a new bord if you want to upgrade your memory to
    more then 1gb pc3200 ddr dimm
  • rush2aaman
    or check sum low MHZ then 400MHZ memory modules
  • 13,433 Answers
Please provide more information.
  • 3,037 Answers
Please check out the following link and if it doesn't help, please let me know where the message occurs while loading and the exact wording of the message or anything else that would help describe your problem
http://support.microsoft.com/kb/326676
  • 6,487 Answers
Can you please inform us some information like was it working fine before with the same RAM and also what was the last thing you did before this problem started...
  • Mark Gil
    Mark Gil Oct 20, 2008
    If the device driver wont load to this computer using the installation CD you can try first try to download the software for your motherboard...
  • Mark Gil
    Yes it should boot even with one Memory module make sure you buy the RAM that is compatible to your motherboard if your motherboard requires a Double sided RAM or a singlesided RAM because they are different better check it on your motherboards manual......
What memory do I need?
Your machine has 4 DIMM slots. They use PC3200 (DDR400) DIMMS (184-pin). The machine comes pre-installed with 2, 256MB DIMMS providing 512MB of RAM. The largest DIMMs available in the DDR PC3200 are 1GB. If you keep what you have, you can add an additional 2GB of RAM, for a total of 2.5GB. If you are running WINXP 32-bit, this should be more than acceptable. You can replace all four DIMMS and get 4GB of RAM, but a 32-bit OS can only access a little of 3GB of RAM. If you want to come close to maxing out under a 32-bit OS, remove one of the installed DIMMS and add 3 1GB DIMMS. These are old memory and may be hard to find and actually cost more than newer memory.
Aug 01, 2014 | E-Machines T6212 PC Desktop
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Sl-75frv memorys
Dear Sir,
You can install upto 3 GB RAM. i.e. 1GB PC3200 DIMM RAM in each slot.
Please go to BIOS settings & load the defaults. / check following. BIOS settings.
DIMM clock & timing is auto/ detected by SPD (Serial Presence Detect)
Possibly the 1GB RAM you are trying to install does not have SPD / is faulty. Try with a new / working 1 GB RAM.
Hope this helps you friend...
Jul 10, 2008 | Soltek SL-75FRV Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Computers & Internet Logo
David Payne
David Payne
