I have a flash drive, which my problem is when i open it, a message pop up "PLease insert a disk on drive E:" i have used it today in a computer shop but when i used it in our computer lab in school thats the time it begins...
how can i retrieve all my files if my flash disk is empty??
I cant access files and folders on my usb flash disk. on my hp laptop. it runs on home vista. bt i can access my files on other computers. When i plug my usb disk, the laptop fails to locate the usb drivers please advice.
cmmk.I cant access files and folders on my usb flash disk. on my hp laptop. it runs on home vista. bt i can access my files on other computers. When i plug my usb disk, the laptop fails to locate the usb drivers please advice.
cmmk.
You can't post conmments that contain an email address.
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
clean your usb port if it does not work open my comp then watch in that window and keep inserting and uninserting until u see my comp reconize it if you have to do the ladder it is time for a new flash drive they do not last forever
Is this flash drive used souly at home, or do you take it and plug it into other computers? If that is the case, you may want to scan it, before opening it, cause you could be bringing home a virus.
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
cmmk.
