Microsoft Windows XP Professional for PC
Problem for Microsoft Windows XP Professional for PC
Cannot add windows components
By unclejed on Jun 28, 2006
went to add the fax software that comes with xp, and keep getting "cannot copy file" messages. files are locked, and cannot copy them even as administrator.
Comments:
Jun 28, 2006
- i've tried that already, thanks, but there's something messed up with the file permissions in the i386 directory, so even as administrator, i cannot install windows components, even after assigning file permission to the administrator. i've been through the processes outlined on microsoft's knowledge base. the worst part is i have to go in and clear the files that don't get copied out of the registry, because once you try to install them (and fail) the entries get put into the registry anyway, which causes the installer to skip the file next time you try to install it.
Best Solution
posted on Jun 28, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3624 votes
1. In the Copy Files From box, type:
<path>\i386
where <path> is the drive letter and folder path to the i386 folder.
2. Press Retry.
3. Are you using the add/remove program interface?
Put the XP-CD in drive, exit 'Splash Screen'
Do above *before* going to 'Add/Remove Windows Components'
How did it work?
Good luck
Comments:
Jun 29, 2006
- Found something that might be relevant: http://support.microsoft.com/?id=884018
On the esentutl.exe - http://www.csd.toshiba.com/cgi-bin/tais/...'t+install+windows+components&OS=&CN=10&BV_SessionID=@@@@0605524489.1111529783@@@@&BV_EngineID=ccceaddeehkgjehcgfkceghdgngdgmm.0&ProductMenu_1=(All+Models)&ProductMenu_2=-------------------------------&ST=1&SortOrder=LT_WEIGHT&awhit=2
I hope it's somehow related
Jun 29, 2006
- The link was to long to catch, I'll break it down here -
su_sc_dtlView.jsp?soid=891986&ref=AI&ct=SB&IL
=EN&QS=can't+install+windows+components&OS=&CN
LT_WEIGHT&awhit=2
Was this helpful?
Yes
No
Solution #2
posted on Dec 15, 2007
Somewhat Helpful)
raghavm
Rank: Apprentice
Rating: 70%, 1 votes
hi
i tried everything, all the above options, microsoft website notes, hotfix etc. etc- nothing worked!!! then finally, out of nowehere, i saw the bluetooth icon in my taskbar!!!!
Just disabled the bluetooth icon, tried installing the fax again n....yes. . . .IT WAS DONE!!! no1 thought abt it yet. . ..but 4 me it worked. just try, may b it'l help u too....
Was this helpful?
Yes
No
Solution #3
posted on May 01, 2008
Not Rated)
Techineer
Rank: Apprentice
Rating: 0%, 0 votes
This worked for me!
The problem is a corrupted security database. See MS Knowledgebase article 884018 for the explanation. That contains a link to another article (278316) with the method needed to solve it.
http://support.microsoft.com/kb/884018/en-us
You will need to determine the location of your %Temp% folder as part of the process. This page helped me figure that out.
http://vlaurie.com/computers2/Articles/environment.htm
Once I reset the security database, I rebooted and did the fax service install from Control Panel-Add/Remove Programs - Add/Remove Windows Components and it went without a hitch.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Windows XP
Questions and Unsolved Problems for Microsoft Windows XP
Do you recommend Microsoft Windows XP Professional for PC?
Answer
Answer
following image problam:C:\DOCUME~1\user\LOCALS~1\Temp\27f2_appcompat.txt
Answer
how to print a tiny label that microsoft labels can't recognize I can't custom the size to print
Answer
recurrent message: resource progress - container empty not found. what does this mean? Thank, Ben
Answer
Two problems. 1st. I can't mail merge from word to excel. Nor can I mail merge from Print shop to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in , DC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
