Question about GoVideo Rave-MP AMP512 MP3 Player
Rave mp mp3 player ---- frozen
My rave-mp mp3 player is damaged n i need help everytime i power it on the LCD screen just reads RAVE-MP. (as if were frozen)I cannot shut it off unless i take out the battery. Also when i plug it into my comp. with my USB plug it has two drives (F & I) yet they do not show anything just r blnk what should i do?\thanxs jimmy dean
It occasionally happens on mine. I just basically have to hook it up to the PC and reload the firmware. (Tnough it seems the company is no longer in business, you might be able to find the firmware update file out on the net somewhere.) Seems to freeze up more if I have the SD memory card in there. Had better luck with some types of SD cards than others (faster speed cards seem to cause me less probs.)
Posted on Aug 08, 2007
HI¡¡ a friend gave me his rave mp "style" or something (the thing doesnt show any alphanumeric serial for model duh)and has the same problem, i tried removing the ST1 drive and the lcd screen stopped flashing but i dont have another hard drive to test it, i guess that buy a new one and install it can solve the problem (lets be realistic for a hard drive that small... failure is not a choice is a must lol) hope this info is usefull.. PD: if my english sux is because im just learning it.. y el espa?ol es una mejor lengua¡¡
Posted on Jun 14, 2007
Try a separate SD memory card (no bigger than 512mb). Also try replacing the battery if you haven't already. Mine has done this intermittantly since it was about a year old.
Posted on Apr 25, 2007
SOURCE:
Computers not seeing the Rave MP3 player
Sounds Like you need to get device drivers for this MP3 Player. Try driversguide.com or drivershq.com. Hope this helps
Nov 19, 2010 | GoVideo Rave-MP ARC2.5 (2.5 GB) MP3 Player
Ilo Mp3 player
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
Sep 18, 2007 | iLO MP3 Player
How do I delete songs existing on Rave.mp ?
Once you can connect the device to your computer, it should popup like a use device that you can delete the songs or file you want.
Aug 17, 2009 | GoVideo Rave-MP AMP128 (128 MB) MP3 Player
Rave mp
This means that your unit is defective and is no longer working. The hard drive is bad.
I have bought 3 of these players. All of them worked for a while then had the eventual face/bug on the screen after turning the unit on. When the customer service number DID work, they said that the unit was defective and to return it to the store and get another.
This happened to me, like I mentioned, with 3 different units.
Aug 10, 2008 | GoVideo Rave-MP ARC5.0 MP3 Player
Windows xp wont recognize usb connection from rave. Is there a driver I need?
If you're using the retractable usb cable that came with the player, replace it. I had the same problem. XP recognized that there was a device, but couldn't open it. I was getting a "Driver not installed" error in device manager.
Jun 08, 2008 | GoVideo Rave-MP AMP512 MP3 Player
Rave-MP AMP126 MP3
This slot is for an SD card. You use this to expand the amount of music you
can hold.
Mar 24, 2008 | GoVideo Rave-MP AMP512 MP3 Player
Rave-mp 128 mp player
Have you tried using the install CD to re-install the player?
Or you can go in windows and under folder options, click show hidden files and folders. And hide operating files.
This will show all the files on the CD.
Remember to restore the settings to normal after you have done.
Nov 24, 2017 | GoVideo Rave-MP ARC2.5 (2.5 GB) MP3 Player
SD Card
Mine works with 2GB card... AFAIK, that's the max, although I haven't tried a 4GB card.
I found updated firmware at:
http://uiss.max.io/
*update*  site has not been updated and download links not working... useful info there nonetheless... I will put the file(s) on my site:
http://french.moren.ca/rave-mp/Rave-MP-Install.zip
http://french.moren.ca/rave-mp/iLO256Manual.pdf
expect them up there by Oct. 20/07...
the ILO player referred to there is electronically identical, if not physical and the update works with all the Rave MP AMP series. I had a hard time finding this but it was worth the effort.
works great :-)
Sep 05, 2007 | GoVideo Rave-MP AMP512 MP3 Player
Rave-MP 5.0
There are 2 issues- 1 the keys are locked - unlock and turn machine off. the other option is to recharge the battery
Jan 26, 2007 | GoVideo Rave-MP ARC5.0 MP3 Player
GoVideo Rave-MP AMP512 MP3 Player Logo
275 people viewed this question
Top GoVideo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a GoVideo Audio Player and Recorder Expert? Answer questions, earn points and help others
