Question about Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh aficio 1022 sc 546
Hola, tengo dos aficio 1022 con el codigo sc 546. se le cambiaron termostatos, temistores, se verificaron las lamparas y se resetea el codigo con el 5-810, pero funciona unas cuantas copias y se bloquea de nuevo.
Por favor si alguien tiene una sugerencia para este inconveniente
Gracias
Adrian Garcia - Argentina
  • 1 more comment
  • app_3rp97493
    app_3rp97493 Jan 03, 2013
    Error SC 541 for Ricoh 2022 .... What can i do ?
  • app_3rp97493
    Error SC541 for ricoh 2022 .. what can i do ?
  • Anonymous Mar 23, 2014
    aficio 270W copias con lineas blancas
Problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Posted on Jan 07, 2010
    Problem Solver:
  • 4 Answers
SC-546 is "Warm-up" error, suggests that the fuser is NOT reaching 160' within standard warmup time.
You might be able to take out the fuser, remove fuser cover, remove carbon buildup from thermistor.
I had to change our fuser at 180,000 copies (service is at 120,000)
Posted on Jan 30, 2009
U need to reset this code &any sc540 fuser error by going into service mode 5-810 to reset also u can try entering service mode& turning offthan back on
Posted on Jul 16, 2009
DEAR SIR,
We have got RICOH AFICIO 1022 Machine. error SC542 comes . Can any body suggest the solution ?
Best Regards,
S.Madhyasta
Posted on May 27, 2009
    New Friend:
  • 31 Answers
Things to be checked when error codes 5xx show up:
-Thermistor (senses the fuser roller temperature) Damaged or dirty
- Thermal fuses (overheat protection) open
- Heater lamp (heats the fuser roller) open or exausted
- Connectors and metal contacts, already happened to me
- Power supply failure (intermitent components or connections on the board)
-Power surges
- In some models like 1022, 1035/45 ,etc, the doors switches ocasionly produce fusion or laser error codes, because their bad contacts interrupt that functions, it happened to me 2 times, just wash them with benzine or replace them.
Posted on Mar 02, 2015
SOURCE:
Hola le acabo de cambiar los empaque a mi 300 crysler y cuando ya avía terminado le quice echar agua y empezó a liquiar agua x un ojito que está junto al termostato
Se me hace que el empaque se movio cuando tratatse de hacer el reparo. Ponle un poquito de empaque liquido en un lado de el empaque, ponlo y deja unos minutos (como 10 minutos) y pon las partes juntas y apriete los tornillos; pero no muy apretados. Deja como 20 minutos y aprietalos bien; al torque aprobado para la parte. Ten cudado de poner el termostato al lado que se debe poner. Perdon de mi deletreado, tengo mucho de no escribir en mi idoma.
Nov 22, 2014 | 2006 Chrysler 300
Hola mi carro le prendio la luz del motorsito esto que quiere desir el corro es un chebrolet cobalt ls 2006 que tengo que aser cuando aparese esa luz
Debemos asumir que esta refiriendose a la luz testigo del trablero que indica "Check Engine"...
Cuando esto ocurre, al computador del vehiculo le esta advirtiendo del mal funcionamiento o una se?al erronea que esta enviando algun sensor. Lo primero que hay que hacer es "escanear" la computadora con un Lector de Codigos, asi podremos conocer el "numero" exacto de este codigo, de acuerdo con esto, podremos iniciar tareas de diagnostico y reparacion.
Mantengase en contacto y envienos el codigo cuando lo haya determinado.
Sep 16, 2011 | 2006 Chevrolet Cobalt
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
Se apagan las luces delanteras
hola tengo una envoy 2003 y las luces cortas se apagan derrepente ya la lleve con mecanico y le cambiaron la palanca de las direcciones y otra cosa donde se prenden las luces pero de todos modos sigue hacienda los mismo me puede decir por que
Sep 18, 2010 | 2003 Mercury Grand Marquis
Tengo una gran cherokee 200 limited 4.7 de 8 cilindros; el preblema es de que se para, se apaga continuaonsejo con mayor frecuencia en la ciudad y un poco menos en carretera pero sigue sin poder usarse...
Hola, al parecer tienes problemas con el idle. Revisa si el vehiculo tiene la lampara de "Check Engine" encendida, en cuyo caso puedes llevarlo a "Advanced Auto Parts", donde pueden leer gratis el codigo de la falla, y podras saber con mas precision cual es le problema del Jeep. Tambien seria buena idea que lo llevaras a hacerle una sincronizacion completa, y haz que le revisen la manguera de vacio.
Aug 26, 2010 | 2000 Jeep Grand Cherokee
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
Oct 03, 2009 | 1993 Isuzu Amigo
I have always error code 546 and 960
Error Code SC 546 is for fusing & SC 960 is for Current leakage, If u getting it regurally , change the thermistors for error code 546, & for error 960 change drum & charge roller.
Aug 16, 2009 | Ricoh Aficio 450 Copier
ROCIO DID YOU FIND THE PROBLEM WITH YOUR CAR DID YOU SPEAK SPANISH GIVE ME A HAND PLEASE
Hola!
Si lo solucione el carro ya esta bien, le cambiaron el sensor crankshaft y le limpiaron el camshaft son dos sensores que estan en el motor, puedes encontrar mas informacion en internet poninedo la palabra crankshaft en el buscador, de cualquier manera te aseguro que eso va a solucionar el problmea, tambien le arreglaro la marcha despues de eso porque se barrio el engrane de tanto intentar encender el carro, pero ya no tengo ningun problema, espero puedas arreglar tu carro y cualquier otra cosa que necesites escribeme y si te puedo ayudar con gusto lo hare.
Saludos
Rocio
Dec 30, 2008 | 1995 Nissan Maxima
Ricoh Aficio 1022 All-In-One Laser Printer Logo
3,999 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
