Question about Frigidaire Kitchen Ranges
I replced my bottom element on my range model number fef365bwc oven still doesn't heat up,but the broiler does
  • 417 Answers
You probably have a faulty thermostat/control switch. Check them out with a multimeter or continuity tester (better to do this with the power disconnected at first).
Posted on Oct 20, 2008
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
I have an Amana stove model ART4002W. The oven will not heat above 250 degrees and the broiler element will not turn on. I replaced the broiler element and the heat sensor. No change.
if you have it on broil and the element doesn't heat up and you changed the element then you either have a loose or broken wire or a bad clock assy. part number 74009213 and it's around 166 dollars
Feb 11, 2011 | Amana AER5715QAS Electric Kitchen Range
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
My broiler and range work but my "bake" option will not produce any heat??? Please help!!!
If this is an electric range, it sounds like you have a bad bake element in the oven. The broiler and bake features each have their own heating element. Thats why the broiler still works. The following link explains how to replace a heating element in an electric range:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If the model range you have this question listed under is correct, the part number for a replacement element is WB44K5012. It lists for about $25 at pcappliancerepair.com.
If you have questions, or if the model number is not correct, please post back with your information so that I may be able to provide you with better assistance.. I hope you find this information helpful.
Oct 15, 2009 | Hotpoint RB757 Electric Kitchen Range
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
107 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
