Question about Refrigerators
Icemaker doesn't work
I have a Westinghouse side by side Fridge Freezer and the icemaker has stopped working. The water dispenser is still working but is not flowing into the ice-tray. I think it started when the whole ice holder thing somehow got pulled out a little. I'm pretty sure it's in properly now.
I've tried turning the power off and on.
Thanks
  • 2 more comments
  • jcw032446 Oct 20, 2008
    water works but ice maker wont fill
  • NoiceforGnT Oct 20, 2008
    Thanks Philtac. I'll give that a try and let you know.
  • gac6713 Mar 16, 2009
    Have a GE mod TFX22ZRSM side by side. Can't get ice to the ice maker all the time. In 48 hours, only got 2 set of cubes. Seems like solenoid doesn't work all the time.
    Ice maker doesn't fill with water
    Scholar:
  • 57 Answers
Sounds to me like you did not get the ice holder is not in right, I would remove it and install it again. maybe a few times if I had to. If your water dispenser is working your water supply is good. You may also have to wait a day to get it to work right the ice maker will not fill until the temp of the freezer gets down. Also make sure the full bin arm is down. hope this helps.
Posted on Oct 20, 2008
Why has my GSS25 ice maker quit working? Water dispenser is fine.
The icemaker could be frozen where the water supply comes into the icemaker this sometimes happens if the water was recently shut off or you had low water pressure. Unplug the fridge and try using a hairdryer to defrost where the waterline comes into the freezer. I would assume you already checked to see the icemaker was turned on and the bail was in the down position. If you did All things i mentioned plug in the fridge and test if it still won't make ice afterwards you will need to replace the icemaker. The replacement should come with instructions.
Aug 01, 2014 | GE GSS25JEMWW Side by Side
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Frigidaire ice maker not working
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Icemaker not filling with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 01, 2009 | Maytag MZD2669KE Side by Side Refrigerator
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
Post back if you need instructions on reparing it.
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
No Water in Ice Maker
before u call a repair man i would unplug the fridge for 12 hours about depending on weather to let ur line unfreeze if thats the problem the dispenser in the door and the one to the icemaker are two different lines so just because the door works with water dispensing doesnt mean the freezer line isnt froze over
Mar 20, 2007 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
618 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
