Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Ice maker line
I attached the water tube to the back of the refrigerator, (the line which is connected from the main water source) got up this morning and my basement is flooded! Why did the line come off? I used a 1/4 inch brass insert and delrin sleeve with a 1/ compression nut and connected this to a 1/4 inch plastic water line. Help!
Diana
    Scholar:
  • 57 Answers
The plastic water line uses a little brass sleeve that insurts on the inside of the plastic pipe. This allows the compression ring to press down and pinch the plastic to the sleeve. make sure you get the plastic pipe pushed in as far as it will go @ 1/4 inch. pemember your working with plastic do not over tighten it will cut the plastic.
Posted on Oct 20, 2008
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
Loose fill tube on ice maker Maytag side by side
Please look around your refrigerator fresh food section door frame for a model number. I believe the reason water is leaking inside freezer is a defective water control valve that you attached to with water line on back of most refrigerators.
I am here to help just let me know, Thanks Sea Breeze
E-Mail
Nov 20, 2012 | Maytag Refrigerators
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
Which water line or lines do I connect to refrigerator, model # ED22RFXW01, man. 08/99
It's advisable to go with flexible plastic tube with sweet water supply. Please follow the instrction as per video attached.
Even if your refrigerator comes withan automatic icemaker, you will need to connect it to a water supply for it tomake ice. While this is not a particularly difficult job it requires someknowledge of plumbing and the use of tools. ThingsYou'll Need:
  • Compression Nuts
  • Knife Or Scissors
  • T-valves
  • 1/4-inch Copper Or Plastic Tubes
  • Drill Bits
  • Variable-speed Drills
  • Drill Bits
Read theinstruction manual that came with your refrigerator. Specific instructions forhooking up the icemaker may be included. Locate thepipe nearest the icemaker that carries cold water. Most often, this is the coldwater pipe that connects to the kitchen sink. Install at-valve in the main cold water line - not on the 3/8-inch faucet tubes - sothat there are two outlets: one to the sink and one to the icemaker supplyline. Turn offthe water. Put asleeve and compression nut over the line that will supply the icemaker in orderto tightly connect it to the water line. Turn thewater back on, and, holding the end of the tubing in the sink or over a bucket,flush the line to remove any debris. Turn the water off again. Snake theline from the water source to the icemaker connection, drilling holes in thebacks of cabinets if you have to in order to push the line through. Find theicemaker inlet from the refrigerator and attach the other end of the line usinganother compression nut. Turn thewater back on. Throw awaythe first few containers of ice to be sure the line is completely clean beforeyou use the ice.
http://www.youtube.com/watch?v=vB-uUMsckSA&feature=related
thanks.
Feb 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
The water supply tube in the back of the refrig pops off when the refrig attempts to make ice. There is no clog in the supply line. How do I check the attachment that is attached to the back of the...
if you think it's clogged it's probbaly iced up,use a hair dryer and melt it out,see if you can put a hose clamp around the hose to hold it in place,does any water make it into the ice maker?see if you can stick a straw oonto the piece the tube slides onto and see if you can blow through it to see if it's clogged or it's just the water pressure blowing the line off,might just need to be attached better
Jan 27, 2010 | Amana ABB1927DE Bottom Freezer...
I need to install a new fitting (part # 2196157). That is the fill tube on the ice maker on our whirlpool refrigerator (model number ed2fhgxkt00) The water line is already detached since the threaded part...
Yes that s it. You may have to tug a little to get the old one out as sometimes the foam will try to hold them in a little tight.
One thing to check before you connect your water line. Take a look at the end of the water line for a minute make sure that no water is going to drip out of it. If it does you may as well replace the valve because that is going to plug the tube with ice and possibly damage the ice maker.
Reconnect your water line and flip the ice maker on and the water should start to flow shortly. That s it.
Thanks for asking.
Nov 20, 2009 | Whirlpool ED2FHGX Side by Side...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water leaking from ice maker GE model# TFH22PRS
Hi
Please check to make sure the water tubes are attached properly and are fastened tightly.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 16, 2009 | GE Refrigerators
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
105 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
