Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
L1928NV When the monitor is first powered up, it will work fine for about ten minutes. The screen will then go blank. When you cycle power, the screen will illuminate again, but for only a few seconds. I believe the problem is heat related. Any ideas on what part is causing the problem?
  • KayakerNC Oct 21, 2008
    My monitor is having the same problem. It is less than a week old, and worked fine for 2 days, then the screen went black. Powering off and on again, the screen stays on for 2 or 3 seconds, then goes black again. I purchased this Westinghouse L191HW from Best Buy and will be returning it tomorrow.
  • jtracerx69 Oct 28, 2008
    same as terio1960's problem
    Novelist:
  • 159 Answers
The problem on monitors when this happens is usually a powerboard problem in which the capacitors are failing due to age and use. Once in a while a transistor goes bad, but since it does run for a bit, it should be your capacitors.
If you can take it apart, these are usually noticable, If you send or post a picture, I may be able to tell.
ebay board repairer,
bammbammfran
Posted on Oct 21, 2008
After a couple of minutes operation the screen goes blank. Switch the power off for 30 seconds and it refreshes and works ok for a couple of minutes tahen repeats all over
the problem of ur monitor is the power supply board,it is located in the inner part of ur monitor,technician is allowed for that problem.you need to call a technician for repair.
Oct 03, 2010 | Westinghouse L1928NV Monitor
My samsung syncmaster 920nw picuture goes blank after a period of a couple of minutes. If I turn the power off and then back on the picture re-appears but goes off again. It is not he pc since it works...
If you get a flashing screen which show your screen for few minutes and then goes blank it may be an issue with the Monitor.
Try to restart the computer and go to BIOS setup screen. If you experience the same issue in BIOS then the monitor needs a repair or replacement for sure.
Jul 19, 2010 | Samsung SyncMaster 920NW Monitor
Monitor keeps going blank, then once this a.m. it cycled in colors, white, red, green, blue, grey- very weird... what's up with that?
it's doing testing in color codes to refresh the color on the screen, if it keeps going blank, that's usually a sign of monitor going bad.
Oct 16, 2009 | Westinghouse L1928NV Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Chi me monitor goes blank on screen save (does not come back on)
damaged power board replace it or replace the monitor
Apr 02, 2008 | Smart Modular SV3170A
DEAD SCREEN
Disconnect completely computer and display form power cable for ten minutes, plug them back and restart ().This is called hard reset.
If you still have the problem try checking the display video cable, both in the monitor and computer socket.
If it still does not work connect PC to a different monitor, just to test that is not the pc or the video card the problem.
If it still does not work the blackout may have caused a short in your monitor or a system failure on pg then get back here and post the new problem.
regards
Mar 13, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
HP mx 70 Monitor
This is a problem usually with the Power Supply unit inside the Monitor. Often it is the Electrolytic Capacitors arround the Heatsink area. They dry out and go faulty.. It is generally a job for the "Shop" I get them all the time... But in saying that intermittent faults are the hardest to find.. If you do take it to a shop, ensure you get a firm "Quote" and explanation B4 proceeding.
May 14, 2007 | HP mx705 17" CRT Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
115 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
