Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Problem for Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Error code AO1
By nicky on Jun 27, 2006
dishwasher working ok on last load, when dishwasher switched on the LCD shows the selected program and you can hear the motor trying to pump the water into the machine after 10 seconds the LCD display shows the above error message (AO1)and no water has enter the dishwasher...
we have checked the filter and also jiggled the water piupe but to no avail. HELP
Same Problem
Apr 28, 2009
-   Holavastoviglie AristonL73nduo mi segnaAO1 cosadevofare-   Guest
Best Solution
posted on Mar 18, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just fixed my DE73 with error code A501. Found it still running overnight, water on floor. Emptied machine of dishes. Tried to restart it a few times - A501 every time. Shut door of machine. Make sure you have a mop or something to soak up water in front of machine.Tipped it forward about 70 degrees. Water ran out through bottom of door (I think). Tried short programme with machine empty. Ran ok. There must be a sensor somewhere that registers water overflow in base of machine.
Solution #2
posted on Apr 07, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
just fixed our error code a01 by tipping the machine forward 70 %.
Solution #3
posted on Jun 27, 2006
Very Helpful)
dovi
Rank: Guru
Rating: 88%, 2515 votes
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line.
If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective.
Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem.
Goog luck !!
Was this helpful?
Yes
No
Solution #4
posted on Mar 23, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Couldnt find the book on my indesit dishwasher but tried dovi suggestion and it worked.A01 kept coming up. cleaned the filter and the arms. still now working. sounded like the pump was running but as soon as i put it on a cycle after a few seconds error message a01 came up. Tipped the machine forward about 70% tipped it back. Machine working lovely again now..
thanks dovi
Solution #5
posted on Apr 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Tipping it does the trick. make sure you have some towels at the ready though
Solution #6
posted on Apr 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ppppppppppp
Popular Solutions for Indesit 24 in. DE73 Evolution
Questions and Unsolved Problems for Indesit 24 in. DE73 Evolution
Do you recommend Indesit 24 in. DE73 Evolution Free-standing Dishwasher?
Answer
Answer
not washing properly bits still on crockery also tablet door doesnt always release cheers
Answer
I start up the dishwasher then after a while I get the error code A03 flashing. can you please tell... (More)
Answer
A08 error code (aux motor triac) what actually needs replacing?
Answer
Has not been used for some time ( 2 years ) as it displays an error R02
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Boardman, OH
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
