Question about Whirlpool 24 in. DU850DWG Built-in Dishwasher
DWF 413 dishwasher
This is a built in (under counter unit)type 12137. Purchased from swedish furniture store. 450mm in width. It has 4 settings. The problem I have is that I started a wash cycle as normal & about 3 -4 hrs later noticed that it was still going. I opened the door, stopped it & noticed the the water had not drained away. Upon emptying the dishwasher, I noticed that the water was dirty & greasy so I guessed thast it was blocked. I stripped all filters & removable arms ETC as per instruction book, cleaned everything & restarted it. Left it switched on for half - one hour (supposed to reset after 10 - 15 mins but nothing happened. I then checked the U bend to see if the was blocked but was clear. Why wont it reset itself? Does this meaen that the dishwasher itself is still blocked? or do I have anothe fault? please help as I/we are sick of washing dishes the old fashioned way!
  • 3 more comments
  • darren catlow Jun 28, 2006
    No, I havenot checked the pump. Not sure how to. Would I need to remove the dishwasher from under the counter? As the machine does not reset, there is no way I can check to see if it pumps out any water. Thanks, 68bug
    O.K., I think that the pump is cleared/unblocked but the dishwasher still won't reset itself as per instruction manual: Quote "if you open the door during the wash cycle, you must wait at least 1 min, with the door ajar before starting the dishwasher again. If the dishwasher is stopped during the wash cycle, when started again it resumes the wash cycle from where it was interupted."
    This is where I am stuck. Is there a manual override so that I can reset it to try the wash programme again? the end of cycle light is not on & it did not buzz as it would normally.?
  • darren catlow Jul 01, 2006
    O.K., I used a wet n dry vaccum cleaner & sucked out water from the waste pipe. I then removed the plug form wall socket as you suggested. Let it out overnight. I replaced the plug & switched it on. I tried a different setting but did not work. I then tried the original program that it stopped working on. It did not work. I then poured water into the dishwasher just above the filter. I then sucked out the water from the drain hose. This emptied the dishswasher & I hoped that it would clear any blockage. I then repeated the programs, did not work. I then poured water into the dishwasher, switched it on using the original program & it worked! however, it did not empty itself, just swished the water around the dishwasher, left this running for 1 - 2 hrs. Then swiched off. I have guessed now that it must be a dead pump? I have not removed the dishwasher yet.
    Do you think the the problem is a non working pump? if so how easy are they to change & wher is it located?
    Thanks again.
  • darren catlow Jul 09, 2006
    I have now changed the outlet (drain) pump. It will not reset itself & it will not end the cycle that it is on. I have tried all suggestions but still exactly the same fault exists.
    As an extra to above, I have taken the cover off the electronics to see if there are any loose or damages wires. I could not find any. However, there are 3 round plates with wires attached I guess some kind of sensors?? these touch the cover plate next to the tablet & rinse boxes these are loose - should they be?
    also if I empty the dishwaher manually, & refill it manually apprx 3ltrs of water to do this, (it fills just over the salt container lid) the machine will empty most of the water out. It will then continue to cycle the remaining water around & around the machine it will heat the water but not take in any water?
  • 641 Answers
What about the pump, did you checked it ? Does it drains water out the machin ?
Posted on Jun 27, 2006
  • Dov Dror Jun 28, 2006
    You should have at least (for the beginning) an access to the drain line output, and to see if water come out.
    If needed, you should remove the dishwasher from under the counter.
    Good luck !!
  • Dov Dror Jun 29, 2006
    Does the dishwasher drained the water out ?
    To reset the machine, try to take out its power cable and reconnect it back after 1-2 minutes.
    In case you still have water in tub,find the way to drain it out manually and start a new cycle.
    Let us know if it solve your problem.
    Good luck !!
How do i find out dimensions of my dishwasher
Just measure the width of the door, as built in dishwashers are all made to fit under the counter, the width is the only number you need
Oct 12, 2014 | Dishwashers
What is width depth height specs
Good Morning Friend,
I see that you are looking for the width, depth, and height of the Frigidaire dishwasher, model# FDB636GF. The measurements are as follows:
Width: 23 7/8"
Depth: 24 1/4"
Height: 33 3/4"
Hope this is helpful.
-Best regards-
WP
May 28, 2014 | Frigidaire 24 in. FDB636GF Built-in...
Whirpool dwf 407 restart cicle
I need more info but it sounds like the main contact or board relay is stuck or short together sound the unit is always powered.
Apr 01, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
DOES JENN AIR HAVE A REST BUTTON, MY DISHWASHER WONT START. MODEL NUMBER JDB4000AWS
first of all if its a built in dishwasher under counter by the sink,check for a switch as you may have inadvertentally switched this switch off or unknowingly bumped it with something under the sink,then if it has power to the unit,there is a built in fuse on the control board
Nov 26, 2010 | Jenn-Air JDB4000AWS Stainless Steel...
How to mount into counter
there are normally a kit with mounting screws and clips to hold dishwasher in. also you can adjust the lower legs.
Feb 24, 2010 | LG LDF6810 Built-in Dishwasher
We have a Bosch shu33 it started running a longer cycle& no longer shows the sanitized light
I got answer from previous post on your site by 'boeschbrady'.Person had same problem,also said part was under Warranty. we called the store where unit was purchased and my unit is also under Warranty "less than 5 years old' repair man is coming next week.Thank you for a
great site Patee
Jan 11, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Manual for Hotpoint Aquarius dishwasher - DWF 34
hi
you want
Hotpoint Aquarius dishwasher - DWF 34 manual no.dont wory go to how stuffworks.comyou can get all info you want.please rate it
Nov 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Whirlpool dishwasher DWF B00 W
get back to me and tell me if it drains or stays full of water and did you do work on the plumbing in the kitchin
May 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU850DWG Built-in Dishwasher Logo
407 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
