Question about NEC LT60LPK Projector Lamp for LT220, LT240, LT240
Unlock keypad on lt240 projector
Hi How do I unlock keypad on lt240 projector
If you do not know the password, then NEC can unlock the keypad after you show proof of ownership by providing the purchase receipt. Other than that it only be resolved by taking the projector to an authorized service repair center with the purchase receipt. This is the safety feature NEC employs to ensure they are providing service for the owner and to deter theft. It is a frustrating and expensive process but well worth knowing that if a projector is ever stolen, the projector basically is locked from use. Expect to pay over $200 to unlock the keypad if you take it to a repair center.
Posted on Sep 26, 2009
How to reset the lamp counter on nec lt240 without remote
holding down the "OFF" key on the remote control for 30 seconds
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Aug 13, 2014 | NEC LT60LPK Projector Lamp for LT220,...
Unlock keypad
I made the same mistake. The solution was to update the firmware. After the update, all settings were set to default---including enabling the projector's keypad.
Apr 17, 2013 | InFocus In122 Svga Projector - IN122
How to manually reset an nec LT 260lp
Have a nice day!
Jerry
Lampdeng Limited
Mar 09, 2013 | NEC LT60LP Projector Lamp for LT240,...
I have a LT60LPLK lamp and I wanted to know how I could test it, outside of the projector, to see if it works.
Don't even think about because lamp is supplied with high voltage and You can get snapped realy badly as well You can blow ballast if you short something
Bad idea!!!
Aug 20, 2011 | NEC LT60LPK Projector Lamp for LT220,...
How to replace and reset NEC lamp LT60LP
HI
PL GO TO MENU ---DEFAULT --& SELECT CLEAR LAMP METER.& PRESS ENTER THEN SELECT YES.
fOR
M.R MUMBAI -DUBAI
Aug 28, 2010 | NEC LT60LP Projector Lamp for LT240,...
Security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Sep 09, 2008 | NEC LT 260K Multimedia Projector
NEC Lt240 prblem
Hi 80camaro
You could check in the Service Menu if your RGB is the same percentage and at the same run rate.
The run rate is normally 45-60 and the percentage on 50.
I would however recommend that you take it to a NEC agent to get it serviced.
If this doesn't fix it , then you will be looking at a new Mainboard.
Thanks for using Fixya and good luck.
Apr 29, 2008 | NEC LT60LPK Projector Lamp for LT220,...
NEC projector LT220 - replaced bulb, works for 1.5 hrs then switches itself off
Hi Matt
There might be a couple of reasons for this problem.
Best is to start with the lamp - return the lamp to whoever you bought it from and insist on a another new one.
If the problem still occurs you should rather take the unit to a repairer - because it could be the Mainboard or the Ballast ( lamp's powersupply ) that is faulty and will need replacement or repair.
Check if your unit is under warranty - because the replacement of a Mainboard is quite expensive.
Apr 04, 2008 | NEC LT60LPK Projector Lamp for LT220,...
NEC LT60LPK Projector Lamp for LT220, LT240, LT240 Logo
205 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
