I'm using Word 2003. The side scroll bar is taking me straight to Find & Replace instead of to the next page - what have I done? And how do I undo it? Sheila
  • 1 more comment
  • smith1421 Oct 20, 2008
    Yup! There's an arrow at the top, which scrolls up, and one at the bottom which scrolls down. Below that, there are 3 buttons, which used to take me up and down one page, but now take me straight to Find/Replace!
    FANTASTIC!!! Thnak you so much!
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmm...scroll bar, as in on the right side of the screen?
    President:
  • 1,901 Answers
On those three buttons on the bottom....click the middle one. The round one.
12 small icons appear. Click on the one that says "Browse by Page".
Problem solved.
Posted on Oct 20, 2008
How do I enable my scroll bar on the keypad??
I trust that you understand that scroll bars are only visible if more than 1 page is to be displayed. If you have magnified a particular page, the scroll bar may be outside the view of the screen - on the right side, Scroll to the left until you see the right border.
Perhaps you are referring to the touchpad.
The scroll feature on the touch pad is not visible. You enable the touchpad by tapping twice on the upper left corner of the touchpad. A lite will appear in that corner when the touchpad is ON.
Then the scrolling feature is enabled on the right side of the touchpad. Simply run your finger up and down the right side of the touchpad. For more information, refer to the User Guide here:
http://h10032.www1.hp.com/ctg/Manual/c02102005.pdf
Dec 20, 2014 | Compaq Presario CQ62-219WM Notebook
Tip
Change the belt
You need a phillips screwdriver with a good point because the screws are small. Dirt is goning to fall out,so be ready.---O.K.-- I usually sit on a folding chair outside with the vac upside-down on my lap & the handle between my legs.The screws you must remove are located in recessed holes around the brushes & back towards the wheels.These hold on the base plate.Take this off & the drive shaft should be visible.The beater bar (brushes) should slide straight out towards you. (You may want to look for clogs & generally clean this area now.) Loop the new belt over the end of the beater bar nearest the drive shaft & line it up with the gap in the brissles,then slide the beater bar back in place.Now's the hard part--Hold the beater bar in & pull the belt straight back over the drive shaft--Make sure it's on all the way & lined up straight with no kinks or twists. Replace the baseplate (Don't over tighten the screws or they will strip out & not hold) &you're done.
on Sep 26, 2011 | Bissell Pet Hair Eraser Bagless Vacuum
In need of homepage google
Google Chrome has recently changed the way it displays the home page.You now can only see "Most visited" or "Apps".You can still set up http://google.com/ as a home page, but in order to explicitly go to it, you will have to hit the home button, which is right next to the address bar.The other way is to add "google search" as an app at the "Apps" section and click then when you need it.Please also have in mind that the google chrome address bar acts as a google search field, so instead of going to google.com and then typing a search term, you can do it straight into the address bar!
Feb 18, 2012 | Google Chrome
How to enable the arrow keys on Toshiba mini netbook NB205?
  1. press Ctrl+Alt
  2. press arrow key
If that doesn't help click little arrows in the corner of the screen to get to the next page or use the arrow keys to scroll to the end of each row.
When using your browse, (browsers do not have scroll bars). You can get fro link to link, using the arrows at the top of your browser page.
Also, you can use the space bar to move down the page, or hold the left click button and use your touch pad to move around the page.
Thank You For Choosing FixYa~!
Mar 22, 2011 | Toshiba mini NB205N325WH 101" Netbook ...
Hi, I have a problem with the scrolling bar at the right side of the page, when trying to scroll up & down the page it stops & you have to wait about 30 seconds then the bar gets smaller & it...
Hello
This problem of your computer is not due to mouse, i believe your computer is responding slow due to some reasons:
1. Lot of application installed on it, do uninstall software you dont want. 2. Clean the temporary file from your computer 3. Check and Remove hard disk errors 4. Check and clean virus/spyware
You can get helps from this web site as well http://www.microsoft.com/atwork/maintenance/speed.aspx
Hope this helps, if so do rate the solution
Jan 06, 2011 | Dell Inspiron 530 PC Desktop
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba Computers & Internet
Don't have scroll lock on wireless keyboard/mouse combo, what other hot keys can i use?
You can try CTRL CTRL instead of scroll-lock. it was working for me. It is not mentioned in the manual.
Mar 10, 2009 | Belkin F1DK102P 2-port KVM Switch
Windshield wipers not parking
The problem could be a bent parking pall bracket. This is usually caused when you wipe snow from windshield using the wipers instead of brushing off. You need to remove both wipers and the cover from the drivers side. Remove the cover over the wiper motor assembly (held by a plastic button). On the right side of the wiper mechanism is a small tab (part of the wiper bracket). This tab needs to be straight for the wiper park pall to rest against.Carefully hammer this tab straight (or you may have to replace bracket, big job) Then cycle the wiper and you will see the assembly return to park position. Re-install all parts in reverse order.
Hope this works for you.
Jan 15, 2009 | 2003 Chevrolet Impala
One click = many?
the button in your mouse is broken->new mouse?? or try to replace the drivers for it
Jan 06, 2009 | Inland (7232) (07232) Mouse
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
