Question about Plantronics Explorer 320 Wireless Headset
Cannot connect I have a Nokia 6500 and i cannot get my headset and phone to pair up. i have turned the device on and so is my bluetooth but my phone cannot find the device, so will not connect. can anyone help please? nicola
  • Jaco Kruger Mar 20, 2009
    I have exactly the same prob.. i have tried connecting it like you said but nope. I've tried standing in a room with just the handset and the 320, the handset keeps saying no devices found, ive tried numerous handsets... is there, like any way to reset the bluetooth device?
    any more suggestions?
  • 716 Answers
Push And Hold The On Off Switch On The Blue Tooth Till It Flashes Blue And Red. Then Search For The BlueTooth When Found Push The Button On The Blue Tooth Again. Hope This Helps
www.Myspace.com/crossroadstonowhere2007
Posted on Jan 05, 2009
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
I have a nokia 6500 slide i am trying to pair to a nokia bh-105 headset but it will not find it when i search for audio enhancements or paired devices. i have the headset on with green light flashing. any...
try turning off your headset and turn it on again, search on your phone for active bluetooth devices. this should solve your problem.. . . if still the as before contact your product manufacturer. good luck and have a nice day...
Apr 29, 2011 | Computers & Internet
How To turn on the headset bloothoot nokia model bh212
Switch on or off
To switch on, press and hold the
multifunction key for about 2 seconds.
The headset beeps, and the green
indicator light is displayed. The
headset tries to connect to a paired
phone.
To switch off, press and hold the
multifunction key for about 5 seconds.
The headset beeps, and the red
indicator light is briefly displayed.
Pair the headset
1. Ensure that your phone is on and
the headset is off.
2. Press and hold the multifunction
quickly.
3. Activate the Bluetooth feature on
the phone, and set it to search for
Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair
phone. In some phones, you may
If the pairing is successful, the
headset appears in the phone menu
where you can view the currently
paired Bluetooth devices.
your phone and is ready for use, the
Mar 26, 2011 | Nokia BH-212 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
flash quickly.
the phone, and set the phone to
Feb 09, 2010 | Nokia BH-208 Wireless Headset
Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
Sep 21, 2009 | Nokia BHF-2 Headset
How To pair Jabra A125s with Nokia BH-604 bluetooth headset ?? Need Help !!!
Turn ON the bluetooth headset (keep the button pressed for few seconds) and bluetooth connection of your Nokia phone. Search for the device from your phone, when found enter the pass key "0000" (its default) when prompted, set this device as authorized to pair it.
Jul 02, 2009 | Jabra BT125 Headset
Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
3. Activate the Bluetooth feature on the phone, and set the phone
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Mar 03, 2009 | Nokia Bluetooth Headset Headset
Nokia 6500 will not pair with Parrot ck3100
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Plantronics Explorer 320 Wireless Headset Logo
127 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
