Question about Zanussi 24 in. DE6744S Free-standing Dishwasher
Too long for a cycle
About a year ago fitted new pump to this machine-since when it takes forever to cycle through a load(more than 1 1/2 hours for a quick wash.Standard wash about 4 hours).Also does not seem to need salt . Anyone got any ideas?
  • Nick Harris Jul 05, 2006
    seems to be the initial stages taht take too long(I think the "wash" cycle.
  • 641 Answers
There are a lot of reasons could cause this issue. Could you provide us more details (if you have) which cycle's stage "takes" this time (filling water, washing process,draining etc... ) You answer will allow us to direct you the solution. Good luck !
Posted on Jun 27, 2006
  • Dov Dror Jul 05, 2006
    It sound as a water supply issue. Check for un bend water supply pipe and for a clean filter (could be on the tap side or on the inlet side). Close tab before opening the pipe.
    Let us know with your results.
    Good luck !!
SOURCE:
Cycle takes forever and water not heating
FIRST OFF CHECK WITH A MULTI MTER FOR CONTINUITY. THE WATER TEMPERATURE CONTROL SWITCH, THE INLET VALVE, AND UR SO CALLED ELEMENT WHICH I FIND ODD AS HAVENT SEEN A WASHING MACHINE WITH A HEATING ELEMENT B4.
Feb 28, 2014 | Asko W6021 Front Load Washer
Drum will not spin
did he run the diagnostics per the tech sheet within the machine?if it will do everything else but spin out,then the drain pump is plugged,as a plugged drain pump will shut down these front load units,you will need to remove hoses off pump and clean out pump and all hoses from tub to drain stand pipe,by running the diagnostics you can run each washer cycle and see what cycle isnt performing in a matter of 5 minutes versus 1 hour real wash time on some cycles
May 01, 2012 | Kenmore HE2 Plus Front Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
When the timer gets down to 1 minute left and the machine is on the spin cycle, it takes another 10-20 minutes to finish the cycle. The total 40 min. cycle takes over an hour to complete. Does anyone know...
The timer is only an estimate. pull the botttom cover of the front of the machine. There is a cleanout on the water pump, if its clogged it could be the cause of your timer taking so long
Jun 11, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Fridgeair front load washing machine.
My machine wouldn't spin propely and it turned out that the problem was that the water was not draining fast enough. I found several coins in the drain boot and some nickels clogging the artery right before the pump. See http://www.applianceaid.com/frigidaire_frontload_washer3.html for a description as to how to get at the pump. To reassemble, I used a vice grip to hold the clamps open to make it easy to get the hoses on the tubes
Feb 12, 2007 | Frigidaire GLTF1670A Front Load Washer
Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
228 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
