Question about Epson EMP 70 Multimedia Projector
No remote controll. need to change view to ceiling view
Want to hang the Projector to the ceiling. The pitcher is still on normal rear view. want pitcure to change to Cieling view. (upside down). Did not receive a Remote contolle with.
5 Suggested Answers
tinamarie49
  • 34 Answers
SOURCE: the picture become upside down
You need to change it to front/ceiling in the menu function of the projector.
Posted on Dec 05, 2007
SOURCE: Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Posted on Oct 07, 2008
  • 105 Answers
SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
Posted on May 29, 2009
luciana44
  • 292 Answers
SOURCE: picture upside down after installing on ceiling
Try Uninstall the projector and install again.
luciana44
Posted on Aug 25, 2009
I bought Projector DGTEC PR80 and I can NOT find how to rotate the picture, as I hang it on the ceiling.
Have you found a MENU button? Usually the remote has more configuration features. There's usually a Picture section where you can turn the picture upside down or mirror it for rear projection.
Nov 18, 2015 | Office Equipment & Supplies
Not showing entire image on screen
It's possible that your projector doesn't natively support your display resolution, but to know more it would be best if you could provide the following details:
Projector Model
PC Model
Windows Version
Windows Resolution/Refresh Rate
Display type (if laptop) cloned/extended, etc
Thanks!
Feb 18, 2008 | Sharp XR-10X Multimedia Projector
Remote stopped working for Sony, ceiling mounted, projector. Batteries changed.
Try calling 1-800-294-3889 or visit their website at: www.ElectronicAdventure.com to buy a new Sony projector remote.
Perhaps they'll even offer a suggestion or two that may help troubleshoot and fix your particular remote problem...I have no personal or financial interest in the aforementioned business- just trying to help and pass on good info.
I also attached a youtube video that offers a coupon code should you need to buy a new one.
Feb 20, 2015 | Office Equipment & Supplies
Projector only in stanby mode does not switch on
This projector provides two different remote control codes; the factory-set, initial code (Code 1) and the secondary code (Code 2). This switching function prevents remote control interference when several projectors or video equipment are operated at the same time.
When the projector is operated in "Code 2," both the projector and the remote control must be switched to "Code 2." To change the code for the projector:
Select either "Code 1" or "Code 2" in this Setting Menu.
To change the code for the remote control:
Press and hold both the MENU and IMAGE buttons together for more than 5 seconds. After changing the code, make sure the remote control operates properly.
Remote control
Press and hold MENU and IMAGE buttons for more than 5 seconds.
You can change the brightness of the screen.
High ...... Brighter than the Normal mode
Auto ...... Brightness according with the input signal
Normal ... Normal brightness
On start
Note:
•When different codes are set on the projector and on the remote control, any operation cannot be made. In that case, switch the code on the remote control to fit the code on the projector.
•If the batteries are removed from the remote control for a long period of time, the remote control code will be reset.
Mar 12, 2013 | Office Equipment & Supplies
I want to hang it on the ceiling face down, but the it projects upside down!
almost all projectors have a menu setting to allow the image to be flipped when ceiling mounted. Be careful not to confuse this with the rear projection setting which it is also likely to have...this makes a mirror image.
Just go in to the menu using the remote or the buttons on the projector and you will find a setting in there
Apr 05, 2011 | Optoma TS400 Multimedia Projector
How can i flip the screen up side down on the projecter
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
CL-610 RUNCO PROJECTION SCREEN IS UPSIDE DOWN. Some one touched the remote control and I am at a loss to fix problem.
turn on your projector as usual, and using the remote, press the 'menu' button.
the menu will appear on the scree (albeit upside-down), and your looking for a setting like 'setup' or 'orientation'.
some runco's need a special code to get into some menus, but the orientation selection should be easy.
once you find the menu, there are usually 4 choices; front projection/floor mount, front projection/ceiling mount, rear projection/floor mount, and rear projection/ceiling mount.
the most common is 'front projection/ceiling mount'
Dec 08, 2008 | Televison & Video
Picture is upside down on screen
go into the menu using either your remote or the button on the projector itself. At the top are several options i.e. "picture" scr-adj. Click over to the right ONCE to "SCR-ADJ" this stands for source adjust. Then look for something called like PRJ mode (projection mode) This tells the projector which direction to display the image so that incase you want to hang it from the ceiling upside down you can. Click down to that menu option. You will then have to click over to the right in order to see your options. If you are using it hanging on a ceiling you want it to say "ceiling front" if it is merely sitting on a cart or a shelf just put it on "front".
Good luck.
Aug 12, 2008 | Sharp XR-10X Multimedia Projector
Changing settings
Hi cajun51man
If you go into the User Menu of the Projector look for a subfolder that reads either Flip Image or Mirror.
Scroll down to it and scroll left or right - this will switch between the image features.
May 26, 2008 | Sharp Notevision XG-C50X Multimedia...
Epson EMP 70 Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
