Question about Microsoft Outlook 2003 for PC
Outlook hang out
My outlook 2003 hang out frequently when i delete any mail or sometimes when i view the mail . it gets stucks for about 1 minutes and then starts upon properly but after sometime the same problem arises while deleting just give me the suggestion
    Novelist:
  • 208 Answers
I HAVE A QUESTION: WHAT OS ARE YOU RUNNING? THIS WOULD HAVE A LOT TO DO WITH THE PROBLEM. PLEASE REPLY IF YOU STILL HAVE THE PROBLEM.
Posted on Nov 01, 2008
Tip
Microsoft Outlook and Outlook Express Maintenance.
If you are often facing the problem of slowness in Outlook or Outlook Express then the total mails may be on the higher side or the mail file size would have been increased. If that is the case please follow the following steps.
1. If the mails have exceeded more than 1500 mails then create sub-folders in inbox and move the mails into that folder (Note: Classify the folders according to the company or persons or type of transaction or Month wise and move the mails into that particular folder accordingly)
2. Delete unnecessary mails or outdated mails by frequently checking it. Even remove it from the "Deleted Mails" folder.
3. Before continuing the following steps try to backup or export mails and keep a copy of your mails.
4. Compact the folders, so that the space occupied by the email file size gets reduced (Note: Even after deleting the emails, the file size remains the same, only after compacting the deleted space will get cleared at the time of compact and the file size gets reduced.)
(Note: Before doing the above steps be careful of taking the Backup on another drive)
on Sep 11, 2010 | Computers & Internet
When sending e-mail with outlook 2003 some times gets stuck
set your preferences to a lower security level; if this is an office PC, you may have to have IT lower it for you
Apr 17, 2009 | Microsoft Outlook 2003 for PC
Outlook 2007 - Emails sticking in outbox.
Be sure that only one instance of Outlook is running.
You can verify this by openning the tasks manager and ordering process alphabetically.
Kill all redondant Outlook processes.
Feb 17, 2009 | Microsoft Office Outlook 2003 for PC
Outlook 2007 hang ups
These all issues are interrelated. As the outlook hangs it creats problems for the emails which are in the out box & will not allow you to move mails to any other sub folders.
To avoid this problem please follow the below mentioned steps:
1. Open the control panel of your system.
2. Go to the classical View & select the Mails option.
3. Go to the Show Profiles Option.
4. Delete all the profiles from the show profile box.
5. Select the option " Always use this profile".
Relaunch your Outlook, it will creat a new outlook profile for you.
Your Outlook will take some time to retrieve all your old mails from the Exchnage server.
This should help you in Resolving your issue.
Cheers!!!!
Vivek
Oct 19, 2008 | Microsoft Office Professional 2007 Full...
Duplicate e-mails
Here is the solution for you
http://support.microsoft.com/kb/885870
You can also check this
http://support.microsoft.com/?kbid=284404
Or
1. How to stop receiving duplicate email messages
There are a few things you can check to stop duplicate email messages.
Start by checking Rules to be sure that copies are not being made to the Inbox, and make sure that all your rules end in "Stop Processing" actions.
Then check the task manager to be sure that there is only one instace of Outlook running.
Two instances of outlook.exe running can produce two messages arriving at the same time.
You will need to then determine why two instances of Outlook were running in the first place.
Another thing you can do is to delete/remove ALL your e-mail accounts and recreate them. This worked for some people.
Finally, another person had this happen when he had two e-mail accounts set up - using two e-mail addresses, but the same POP3 incoming and same SMTP outgoing.
What happened is that the second account was getting the e-mails from the POP3 server before they were actually deleted after the first account was finished.
If this is the problem you can disable the receive on the second account.
And
2. How to remove Outlook duplicates, including email, contacts, appointments, and tasks
If you have just a few duplicates, it may be easiest to manually remove them. For emails, this is no problem but for any other Outlook item it is easiest to view the items in a table view, then select the duplicates, then delete them.
To accomplish this, go to View...By Category (or "By" anything really). This gets the view into a mode you can work with.
Click either names or subjects (or any shown field) in the column header (in the gray area) to gather similar items together.
You can then delete all the duplicates you find.
You can also check this :
http://www.sperrysoftware.com/Outlook/Outlook-Duplicates.asp
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Microsoft Office Outlook 2003 for PC
Size increase of ms outlook
Negative on that partner...
Your PST (email folder) file should not be bigger than 1.8Gb, once it reaches that size, you cannot receive or send emails.
What you can do is save the email attachments on your hard drive and delete them from the email message itself, saving only the message.
Make PST files that only contain up to 1.5Gb, then create more with other names (like Inbox200712_01.pst, Inbox200712_02.pst) for example.
If you have further questions or comments, please do so. If not and if the answer was good for you, please rate it as FixYa!
Dec 13, 2007 | Microsoft Outlook 2003 for PC
Outlook hangs
Do you have an Exchange server running on the same server or are you popping an ISP for mail? Are you logon locally or is the from Termainal services? Also do you have the whole MS Office 2003 suite installed or just Outlook 2003?
Nov 28, 2007 | Microsoft Office Outlook 2003 for PC
Problems sending and recieving mail in Outlook 2003
I am recieving some of my emails in my sent box not my inox.I am also using Outlook 2003
Nov 13, 2007 | Microsoft Outlook 2003 for PC
Microsoft Outlook 2003 for PC Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
