Question about Akira PK-8401 84 in. HD-Ready Plasma Television
Video wall color matching
I need to know some basics to obtain the same colors on a 9 panel video wall system. Is there any color management software available for this product that is more user friendly
WHAT KIND OF VIDEO WALL IS THIS,IS IT ORION
Posted on Sep 22, 2006
Mixed ink systeme
Match all your clients' custom colors with the HP Indigo Ink Mixing System. This stand-alone device allows operators to mix a wide range of special colors from a set of base inks. The HP Indigo Ink Mixing System combines state-of-the-art color measurement technology with HP ElectroInk to make color matching a precise and predictable procedure. Fully automated software guides the user through steps of measurement and analysis to determine the best color match to the original sample and to mix new ink-easily and efficiently. If you prefer, special HP IndiChrome Off-Press inks can be mixed and shipped to you from HP at any time.
Apr 23, 2014 | HP DesignJet 3500cp InkJet Printer
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
When printing photos, the tones are off, e.g. teeth that we know to be fairly ''white'' appear very yellow. Is there an optimal color combination setting for photos?
You can download the basic color match software from hp, the problem is due to the fact that the color schemes used do not match, the printer prints using cmyk, and what you see on the screen is RGB. using the basic color match software you can create your own color palette and the printer will recognize the new values.
Al
Eliteprintersolutions@gmail.com
Jul 07, 2009 | HP Laserjet Cp2025n Printer
Color matching
If this is a print problem and not just a screen issue, here's what I suggest.
In Illustrator, double click the colour swatch for the Pantone Book colour you are using and obtain the CMYK values.
In Quark, instead of using the same Pantone Book colour, create a new Process colour with the same CMYK values as the Illustrator swatch.
May 20, 2009 | QuarkXPress
Color drivers
Do you mean you do not see color on your monitor display right now?
If so:
1) Find out your monitor model
2) Do a search naming your monitor model (ie) dell 783s) and download the driver specifically for windows 98
3) see below for accessing Device Manager to update the monitor driver:
Microsoft Windows 95, 98, and ME users enter the Windows Device Manager by clicking Start, Settings, Control Panel, System icon, and finally clicking the Device Manager tab.
Below is a basic example of what the Microsoft Window Device Manager may look like when open. Clicking on the below image will open a more readable version of this picture.
Click Image
Dec 21, 2007 | Microsoft Windows 98 for PC
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Color management monitor profile change.
Good Morning aspevak
Depending on the internal video card, you have to install the correct driver for your monitor, and video card, other than that is just setting on control panel and advance setting , all the features, for the colors, or profiles.
Nov 27, 2007 | HP Media Center m7250n (ED842AA) PC...
Akira PK-8401 84 in. HD-Ready Plasma Television Logo
438 people viewed this question
Top Akira Televison & Video Experts
jasbo
jasbo
ray gallant
Are you an Akira Televison and Video Expert? Answer questions, earn points and help others
