Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
Cable to antenna mode
How do i tell if i am in cable or antenna mode? and how do i switch the mode?
  • Anonymous May 26, 2008
    only one channel is coming it. How do I determine if cable mode or t.v mode is on or off. I am aware of the t.v.optiion that tells you but it does not seems to work
    President:
  • 3,130 Answers
You will have to use your remote control and go into the menu. In the menu you will see several options . One will be auto tuning. Go to auto tune or tuning channels. Good Luck
Posted on Jun 27, 2006
When in antenna mode why does it freeze then turn off and come back on in HDMI1 mode?
[PDF]USER MANUAL - Vizio
www.vizio.com/documents/downloads/hdtv/.../UM_E550iB2.pdf
VizioAny other voltage than the specified voltage may .... Do not locate the antenna near overhead light or power circuits, ..... the instructions that came with your mount. ...WIDE. Switch the display mode. MUTE. Turn the audio off or on. BACK ..... Zoom. Normal. Note: Aspect ratio settings may vary by Input source. HDMI-1. HDMI- ...
[PDF]USER MANUAL - VIZIO
cdn.vizio.com/documents/e40c2/um-e40c2.pdf
setting and this is the setting in which power savings will be .... electric shock, do not perform any servicing other than ... connected to the TV, make sure that the antenna or cable system .... Locking and Unlocking the Custom Picture Modes ..... ...... .....BACK. Go to the previous on-screen menu. MUTE. Turn the audio off or on.Missing: freezes
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Jan 21, 2016 | Vizio E420VA 42 in. LCD HDTV
How do I change from cable to antenna?
Without knowing the make and model it is difficult to answer your question accurately. In general you would change either the source or input option. Usually the antenna option is called TV.
Sep 08, 2015 | Televison & Video
Trying to convert from cable to antenna...I get no signal and it seemingly goes into sleep mode
Consult your TV's owner manual and enter "set up mode" to switch the RF or Antenna input from: CATV / Cable to: Antenna / Off Air. Then, allow the TV to scan VHF & UHF for signals strong enough to "tune in". You may need to upgrade your antenna in order to collect enough signal to display video properly. Make sure that your TV has a digital tuner (ATSC) as the old analog tuners (NTSC) have no signal to tune since broadcasters were forced to digital transmitters by the FCC years ago.
Use the site linked below to help you select an antenna that will allow you to receive all signals possible at your location - without buying more antenna than you need.
Like AntennaWeb org
Apr 08, 2015 | Televison & Video
Antenna unrecognized.
Sometimes the TV will lock out other inputs when a cable is connected. Try the antenna by itself and put the TV in Channel scan mode. If this works reconnect the cable TV cable. If that doesn't work you may need an A/B switch
Feb 19, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
Antenna?
HELLO...
I WOULD LIKE TO TELL U THAT ..AT A TIME U CAN USE ONLY ONE CONNECTION....ITHER-CABLE OR ANTENNA.
U CAN CONNECT AN ANTEENA AT THE PLASE OF CABLE ANY TIME U WANT.........
IF U NEED ANY MORE HELP ON THIS....MAIL TO ME
AT-SIGMA_SHIVA1@YAHOO.CO.IN
dont forget to tell me u r problem solved or not
best regards & best of luck.
Oct 23, 2007 | RCA F27669 TV
Going from antenna to cable off the remote
Can you tell me what the remote code is for this unit
Sep 29, 2006 | Symphonic SC3813 13 in. TV/VCR Combo
Tv won't get channels
We have the owners manual in case you misplaced yours . All ya gotta doi to get it is to click on the zenith B32A34Z model # At the top of this page and scroll down to the manual. Now according to the manual in the menu there is an antenns /cable setting and its in the EZ progrom mode. look at the manual as I dont remeber 100% but its there. It sounds like you or someone switched it when they were in the menu. Good Luck
May 11, 2006 | Zenith B32A34Z 32" TV
Where is CATV/Antenna switch?
if its not in the antenna mode settings its automatic or not compadable check with the manufacturer to be sure.
Nov 29, 2005 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
356 people viewed this question
Top Broksonic Televison & Video Experts
Marvin
Marvin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
