Question about Bose Lifestyle 48 System
Bose Lifestlye 48 DVD Plays only in Black & White, was working properly till now. Please assist.
  • Anonymous Oct 26, 2008
    I have the identical problem; all dvd's play in b&w. How weird.
  • Anonymous Dec 28, 2008
    since the sky man came and installed HD
    Genius:
  • Bose Master
  • 1,550 Answers
Check on the remote if got a video sistem function maybe are on the wrong sistem
Posted on Nov 17, 2008
I had the same problem and it was resolved by making sure that all the leads into the back of the system drive were securely pushed in. Mine had been dislodged slightly when being dusted!
Posted on Nov 18, 2008
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
Bose lifestyles v28 plays dvds in black and white
Check your video output settings in the menu. If you are using a composite video output and do not have the system sut up for it, you will get a B&W picture. Check your menu settings.
Aug 19, 2009 | Bose Lifestyle 28 System
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Bose 321 only plays DVD movies in black and white
This happens because the connections are not pushed in fully. Check the connections are push them fully in, they are very stiff on Bose units.
If that doens't help, try a new cable.
Jul 07, 2009 | Bose 3 2 1 GSX System
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it...
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
May 31, 2009 | Bose Lifestyle 48 System
This sounds like a loose s-video cable at the back of the media center (connecting from the VS-2). Check that connection.
If adjusting this cable does not fix this (I'd be surprised) then just reset your media center by unplugging the dc power cable for about a minute and plugging it in again. (while system is off first of course)
May 24, 2009 | Bose Lifestyle 48 System
DVD is stuck in Bose lifestlye 48 media player
We had a power surge during a thunderstorm that dimmed our lights, and after that the CD opened as normal.
A friend suggested that I pull the power connector, press the open/close button and hold it down as I reconnected the power connector. The power surge beat me to that, so I don't know if it works. It was more than "Tech Support" could offer however.
Mel47
Mar 11, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
DVD problem - now only plays in black and white
Check the video connections on the back of the Bose unit. I have a Lifestyle 38 and had an issue with video only playing in black & white. Turned out to be a loose connection.
Nov 10, 2007 | Bose 3 2 1 GSX System
Bose Lifestyle 48 System Logo
197 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
