Question about JVC UXN1 Shelf System
JVC UX1 micro system - ribbon cable damaged
The ribbon cable which connects the 2 parts of the system (amp and radio/cd player) has come adrift from the male plug. I can fix it back on but one of the pins is missing. Do you know where I can get a new plug or pine or other advice how to fix it?
Thanks
Rupert
nuwan chinth
  • 111 Answers
SOURCE: no sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Posted on Jan 13, 2009
SOURCE: Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Posted on Apr 14, 2009
sodeep
  • 3267 Answers
SOURCE: installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Posted on Jul 26, 2009
SOURCE: I have a JVC KD-G421 cd/wma/ipod player and am
i have the exact same problem!!! need help. wont select the input channel, i have radio and cd??? wheres the mp3
thanks
Posted on Oct 11, 2009
SOURCE: My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Posted on Oct 13, 2009
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
A CD is stuck in my bose system How do I get it out?
From an other web site
PART I
PART II
Oct 09, 2014 | Bose & Wave& Music System
I want to wire a subwoofer and amp to player
1. cd player connection, audio out (stereo) rca cable
2. from cd player rca cable, connect it to amplifier audio in (stereo).
3. speaker output wiring connection going to spkr. box.
Apr 16, 2010 | JVC FS-2000 Shelf System
I have a JVC KD SH55 and won't eject CD. Fix please. Recall?
there is a ribbon wire that connects the faceplate contacts behind the faceplate that always go bad on all radios with rotating faceplates. you can probably find this part on ebay or on parts.com or by jvc.
Sep 08, 2009 | JVC KD-SH55 CD Player
Car CD player plays but has no sound
Does your car have a premium sound system? Assuming that your cd deck is fine, try connecting your remote turn on wire from the sony to the corresponding wire on the car(if you bought a wiring harness, just match colors). Also some chryslers used a ground to turn on the amps.. a black wire with a female connector as well as a heavy ground ribbon cable... connect those 2 AND the ground to your stereo to enable the amplifiers.
Jun 23, 2009 | Sony Car Audio & Video
I have a JVC stereo system, cassette, 5 disc cd, tuner, I recently repaired an amplifier problem as one of the output IC's was burnt out. The set works fine if on radio mode. But the cassette and CD player...
I used to fix a lot of these type of units. It wsn't unusual for a wired or ribbon cable to either not get reconnected or not make good contact in it's socket. Also if it was a ribbon cable it good be put in backwards.
Dec 16, 2017 | Audio Players & Recorders
Kenwood m7024
This is the part number for the only ribbon cable that has micro switches on it:
J84-0156-04
You can find it on ebay at this url:
http://cgi.ebay.com/Kenwood-J84015604-FLEX-PRINTED-WIRING-BOARD_W0QQitemZ370055259080QQcmdZViewItem?IMSfp=TL0805270931a14673
Please give me a "fixya" if it helps you.
Those micro switches detect how far the display moves in and out.
All of those type of ribbon cables also have the part number on them. Look at the part of the cable that overlaps the connector that it plugs into. That way you can be sure this is the right cable.
I have fixed many of these type of radios and have not seen the micro switches brake on that cable. They have a very thin piece that gets pushed in, it could be mistaken for a broken switch.
The most common ribbon cable that goes bad on these radios are the one that connects the 2 displays together. It has a metal connector jack on it and the part number is J84-0154-05
Hope this helps
Jun 07, 2008 | Kenwood KDC-M7024 CD Player
Cd player
I would first check for a broken or disconnected wire or cable. then check all of the fuses. After this the unit will need to come out of the car and be bench checked. Good Luck
Apr 03, 2007 | Pioneer DEH-P44 CD Player
462 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
