Question about Fujitsu Plasmavision P42VCA30EH 42 in. Television
No sound coming out my plasmavison w p42vha31es
I have just bourght my telly we plug the speakers in but no sound comes out
You need to plug the speakers into the back for sound.
Posted on Aug 22, 2010
Where is the jack plug socket for the remote speakers to plug into my telly as i can not find it at the back of the telly ?
What make and model tv .
Most if not all flat screen tv's do not have speaker outputs
but they do have rca audio outputs,these are marked audio output
and are round with a red centre,these outputs will require an external amplifier to power speakers.
Len....
Sep 12, 2014 | Televison & Video
No sound
Hi are you sure the mute button isnt stuck on your controll if this is not the case then it could be on the circuit board.
Have you tried changing the sound mode and see if this changes anything.
The only thing you can do if it is a board problem is buy seperate speakers that will plug into the audio out put connectors doing this will let you know if it is a controll or setting problem also if you try external speakers then you would no that it isnt a controll problem if you got sound through the external speakers then the chances are that it is a solder problem if the solder had gone on one speaker you could eliminate that as you would know where to look but as it is both the speakers, Im basing it on that you are using the speakers inside the telly and not external ones if you are using extra speakers unplug them and just try the telly ones.
So basing it on that you are just using the internal speakers then it could be a solder problem on the board where the speakers plug into.
It could be something as simple as a resistor gone or going these are cheap to buy but i dont sugest fitting yourself unless you have relevant testing equipment and a good knowlege of soldering.
So first i would try changing sound modes on the telly if this dont change anything try pressing mute button just to make sure that the controll and all its functions are working properly.
But after this if it dont solve your problem then you could either buy external speakers as this might solve your problem but if you want the telly working as it should be you will need all equipment and to be able to read a spec sheet and be able to follow cicuit diagrams.
Let me know how you get on and what you want to do
Dec 01, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I am having problems with our daughter's tv. The volume isnt working now even though the picture is fine?
Have you looked at the headphone jack? Sometimes a set is left plugged in and sound wil not come out of speakers.
Also, look at cable box. It can sometimes have a separate volume control.
last, if you plug in a set of headphones and you hear sound, pick up a pair of inexpensive powered speakers and use those.
Jul 10, 2014 | Bush 5693D 24" TV
I have a 1980's atari game. How do I set it up?
hi, this round pin with the little pin in the middle this needs to be plugged into the back of your telly it goes into the ariel socket you need to unplug your tv's arial then plug this into where the arial was, now what you need to do is put your telly onto a channel you dont use such as 7 or 0 witch ever one you dont use to watch telly, once you have done this you need to enter the setup mode on your telly to scan for channels so make sure the game is switched on and then start scanning for channels as if you were tuning in the tv channels so do this then you will come across the game so you then save this frequency to this channel.
You can then play the games just remember when you want to play it that you put the telly back onto the channel you tuned in for that game.
Let me know how you get on or if you need further assistance ok
Jan 25, 2010 | Video Game Consoles & Games
Sound wont come out speakers
Not to sound like I am taking the pi**, but arae you sure you plugged into earphone/audio out????
Try using a pair of earphones you know work and if you get sound then the speakers could be faulty.
Nov 06, 2009 | Juster Computer Speakers
Problems with sound/no audio
the internal amplifier IC needs to be replaced to fix this problem
the ic is cheap but not the labor
Dec 30, 2008 | Televison & Video
Connecting to surround sound system
Hi to connect your ps3 to your tv all you would need is a hdmi to hdmi connector which would mean the sound would come straight out of your tv. The sound comes directly out of the hdmi cable. If you want to connect the ps3 to an external reciver you might want to get an AV reciver with HDMI inputs. This would connect to your tv and you can switch channels to different sources connected into the receiver, also they come with very good seperate speakers so you wouldnt have to use you telly speakers and you can connect your directv box into it aswell.
Alternatively you can connect the audio phono outputs from your AV multiout connector on your ps3 (the cable should be provided) to a seperate sound system with phono AUX inputs, these are found on most soundsystems but check with whoever your buying it from. But this means that you cant use the HDMI output of your PS3 for video just the AV multiout video signal (which is a bit rubbish, so I suggest the latter solution.
Hope this solves your problem
Rob
Nov 26, 2008 | Audio Players & Recorders
Fujitsu Plasmavision P42VCA30EH 42 in. Television Logo
234 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
