Question about RCA P50830BL 50" Rear Projection Television
Remote not working with P50830BL
TV works okay but the remote stopped working with the TV. Tested the remote with another RCA TV and it works okay, so believe the problem is with the TV's remote sensor. Can someone offer an inexpensive/ home solution to diagnose and remedy this problem?
    President:
  • 3,130 Answers
Yes it certainly could be a problem with the remote sensor assy., as I have had bad ones from rca in the past, But mostly its been bad connections from board to board or a jumper or even a few times the Microprocessor IC was bad. The best and only way I know to trouble shoot this, without shotgunning part after part and may get lucky, is to scope out the data line comming out of the sensor while hitting a function on the remote. If theres no data comming out then check the b+ going to the sensor also. Trace the signal all the way to the processor. If signal does make it all the way there , then of course the processor is the problem. Now theres High voltage inside these sets, so its not advisable for a handi-persomn to fix this set themselfs. There really are no user serviceable parts inside these sets as they are all soldered in and you need speacial equipment to properly work on most if not all sets these days. I would say a fair repair cost for a problem like this I would estimate at from200 to 350 depending on the exact problem. Good Luck
Posted on Jun 27, 2006
Connected an RCA sound bar to my RCA tv an the remote control wont work anymore
You may have situated it so it is blocking the pickup for the remote. Your remote is talking but the TV can't hear it. Make sure no part of the front is blocked by the sound bar.
Apr 02, 2015 | RCA Televison & Video
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
Can't find code for my sansui tv and rca universal remote
Code for Sansui TV are
1247
1191
Please try the above codes
Thanx
Jul 25, 2010 | RCA RCR311B Remote Control
Need instructions to program tv
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
Dec 09, 2009 | RCA Universal Remote Control
Problems getting a RCA universal remote to work for Prima tv/dvd
after you press the code search button you have to press the dvd button then enter the code
is the remote the rca systrem link?
Feb 01, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
I need a code to make my remote work my tv
i have a rca tv and a magnavox universal remote and i need codes to program
Jul 08, 2008 | Televison & Video
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
Remote problems
Take the remote to your local Radio Shack and have it tested.. They used to carry IR cards and now have a pen-like tester that can tell if the remote is operating properly. Then, if you're sure the code is correct, you probably will have to have the IR detector in the Tv replaced...
Bill
Nov 20, 2007 | RCA RCU300WBL Remote Control
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
