Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
XEROX 2424 is printing in reverse order
Print jobs are printing the last page first. 10,19,8,7,6,5,4, etc. Does anyone know how to fix this??
Check your driver settings, in Layout option some people things that print in reverse order is going to print on both sides but its not. It wil print your job backwards though. So make sure you dont have that selected
Posted on Mar 23, 2009
How can I reverse the order of printing pages?..I have a Cannon and MAC
When you click print, and IF a Print Window opens, then it should allow you to click a button on that window to change the Print Properties. There should be a choice for "reverse order" and you just need to unclick that choice.
Oct 21, 2012 | Canon Office Equipment & Supplies
My printer prints pages
The print job properties screens vary depending upon your OS and the version of your printer software. When you click "Print..." from the File menu in an application, the current job properties come up. You need to look for a box that you can tick or un-tick that has to do with reversing the print order of the resulting pages.
Dec 12, 2009 | HP PSC 1610 All-in-One Printer, Scanner,...
HP officejet 9130 printer: pages keep printing
Yopu can change the rprinting order from the Print Dialogue box or Printer driver.
Look for the following to change page grouping when printed
and the followintg to change printing from first to last and last to first pages
Nov 13, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
Reset Job on Workcentre 24
You need to also clear it from the computer. Open the printer properties on the pc to see if the job is still present. If so, cancel it.
Apr 07, 2009 | Xerox WorkCentre M-24 Color Copier
Hi, my name is Gabriel and I have the Xerox Phaser 4510, I would like to know how to print one page for both sides? Thank you
There ia a duplex unit that you could buy and attach to the machine.
Alternatively when you select "Print"
Select the option to print pages in the range "odd pages
When the job is finished place the printed documents in the manual paper feed and select "Print" again and the option to print all the even pages.
You will also have to check a box to print pages in reverse order or vice versa depending on the order the first batch were printed.
A bit of trial and error might be required before you get the correct solution. Hope this helps??
Dec 19, 2008 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Xerox 2424 Print head not parked
A copule of things cause that.
Here are the main 2.
On the left frams looking from the front, with the covers off, there is a 1 inch square stainless steel print head block that is located about 2/3s of the way back , near the bottom of the frame. Look at that and see if there is ink built up in that block , also under and around the block. If so remove the spring holder thats over the block and take channel lock pliers and remove that block. It may be very stiff. To clean soak it in hot water to soften the ink and clean that block, the shaft and all the remaining ink under the block you can remove. Once you return the machine to working order, take a level and out in on the glass. Make sure it is LEVEL front to back and side to side.
Number 2 is the print heasd wiper is stuck to the print head. That requires removing the scanner/document feed assembly, the side covers, the upper rear cover and the ink loader assembly,( where you put the ink sticks). Once you remove that you have access to the print hear drum area. If needed carefully pry the wiper from the print head and return to service. That blade will stick if the machine is not properly shut down.
I strongly suspect the machine is not level and when you ran the cleaning mode, it sucks all the ink out of the print head. Most likley while that ink was dropping into the tray, it ran out the back of the tray.
Sep 10, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
I need to change printing pages from last to first page first
the last printed page is always on top. For a long document, it takes a while to resort and place the first page first! This is how you can get Microsoft Word to reverse the print order and save all the trouble.
I have spent so much time resorting documents after printing. On my printer, the last page printed is always on top. By printing the last page first (reverse order), the document is already correctly sorted.
Here is how to do it:
1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
Now, all your documents will prevent in reverse order. What a lifesaver!!!
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
Enquiry for best latest machine
The 856o is solid ink printer. DN is the duplex version of the 8560. Price should be less then $900.
All print features are available on it. The hard drive is optional.
  • Rich, vibrant colors on everything from cover-weight stock to recycled paper
  • Adobe PostScript 3 and automatic color enhancement tools ensure reliable and accurate prints learn about Xerox Color Correction (PDF)
  • 2400 FinePoint™ print resolution produces incredible detail and halftones you'll be proud to share
  • Consistent, vivid color from the first page to the last
collapse_off.gif more features
  • No penalty for color because the Phaser 8560 prints black-and-white and color at the same fast speed
  • High monthly duty cycle of up to 85,000 images means you'll get a reliable color printer that will last for many years to come
Features that Enhance Ease-of-use
  • Easy to install on your network with only a few clicks See how easy it is to install
  • No toner cartridges! Just drop the no-mess ink sticks into the Phaser 8560's shape-coded slots, close the cover and you're done
  • Instant on-screen alert notification and help when a print job needs attention thanks to Xerox PrintingScout™ technology
  • Access device and job status as well as accounting information from your computer via the Xerox CentreWare® IS Embedded Web Server
  • Prints are secure with Saved Print feature, which won't print your job until you enter your PIN on the front panel (requires hard drive)
  • Electronically "shreds" data stored on the hard drive after every job or on request (requires hard drive)
  • Real-time paper tray status on your desktop shows all available media types and sizes
  • Up to four paper trays can a hold a variety of media types and sizes
  • Automated online troubleshooting with PhaserSMART™ gets you back to work fast
  • Booklet printing feature automatically arranges your document so you can easily fold and staple it into a booklet (requires two-sided printing)
  • Job completion notification lets you know when your print job is finished
  • Run Black allows printing to continue in black-and-white if one or more of the color toners are depleted
  • Print With feature prints your current job (such as a cover letter) along with other jobs stored on the printer's hard drive that you specify (such as a brochure or two)
  • Personal Print feature can create your own private mailbox on the printer's hard drive where your processed print jobs are stored for quick printing via the front panel or embedded web server
Software Solutions Digitize . . . Organize . . . Distribute . . . Collaborate
With digital documents, you can easily create, search, re-use, and build upon your documents. Maximize your hardware investments with innovative software solutions from Xerox and Xerox Business Partners:
  • Contain costs
  • Share knowledge
  • Accelerate workflow
  • Integrate paper and electronic documents
  • Manage and distribute documents effectively
> Show me the Software Solutions
Pricing Details Prices do not include applicable taxes, shipping, or handling charges and are subject to change without notice. Products are available to qualified business customers installing in the US; subject to applicable terms and conditions, and may be either Newly Manufactured, Factory Produced New Model or Remanufactured; which have been produced to a Xerox pre-determined standard and may contain both new components and recycled components that are reconditioned.
1 Average standard pages. Average Continuous Composite CMY Yield in accordance with ISO/IEC 24711. Yield will vary based on image, area coverage and print mode. Read our Consumable yields guide (PDF) for more information.
2 Approximate pages. Declared Yield on Drums based on an average job size of 3 pages A4/letter size. Declared Yield on Fusers based on A4/letter size 20 lb (75 gsm) pages. Drum and Fuser Yields will vary based on job run length, media type, size, weight, orientation, and usage patterns. Read our Consumable yields guide (PDF) for more information.
Mar 07, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
753 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
