Question about Optoma MovieTime DV10 Multimedia Projector
Projector to laptop
I have aoptoma data projector and need to connect it to a laptop for a presentation..What chords do I need ...where can I get them and how do I do it...
Thanks
    Brigadier General:
  • 6,966 Answers
Your post:
  • cords/cables - would depend on what are the available OUTputs from your laptop. Some examples are DVI, 15pin VGA, S-Video and the single yellow RCA;
  • where - would depend on where you are, the DVI and/or 15pin VGA cable would be available from most computer shops, the S-Video and the RCA from most electronic, audio/video stores.
  • how to do it - would depend on the brand & model of your laptop. Normally it would be a combination of the Fn key + F? to enable the external video. Cycling through would yield, LCD only, LCD + external, external only. The F? would be dependent on what laptop you have. Connection wise, it would be a matter of connecting the appropriate cable to match the available output connector of the laptop to a matching INput connector of the Optoma projector;
  • Additionally, depending on the model of the Optoma (more specifically its resolution), it may be to your advantage to initially lower the screen resolution and screen refresh rate of the laptop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 20, 2008
Chords needed for elmo 400af
You are a teacher, and you don't know the difference between a chord and a cord ? Amazing. I think anyway you mean a lead - the one you require has a plug on one end to fit the projector, and a plug on the other to fit the camera. Look in the respective manuals.
Jul 17, 2017 | Elmo Projectors Elmo Ev-400 Af Video...
yes, but i dont even have a cord yet. what cord should i buy?
Sep 22, 2012 | Elmo Projectors Elmo Ev-400 Af Video...
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
Mar 23, 2017 | ViewSonic PJ458D DLP Projector Multimedia...
How do I connect the laptop to the projector using Power Point.
Connect the data projector to the video port on the laptop. Then power up the data projector and then the laptop, the video data will automatically be diverted to the data projector.
If you want to see the Windows image on your laptop screen as well you need to press and hold down the FN key plus one of the function keys on you laptop which has a screen symbol. Pressing this key will toggle between the laptop screen, data projector or both laptop screen plus data projector.
You can open Power Point and select your presentation as you would normally.
Nov 14, 2010 | Computers & Internet
How can i display a portable swivel projector from my laptop using a vga connection? Once im connected all i see is a color bar screen on the wall, do i press something to enable the picture?
There are different types of video outputs which your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Connecting a Macintosh laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Aug 30, 2010 | Toshiba Satellite A135-S4527 Notebook
I can not connect laptop with projector
Instructions
Things You'll Need:
Laptop computer equipped with a VGA, S-Video or HDMI output.
Overhead projector with the applicable input.
VGA, S-Video or HDMI cable.
Software to ready your content for presentation at the correct screen resolution.
DVI-VGA adapter, if you are using a Mac.
Step 1
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Step 2
Step 3
Step 4
Step 5
Step 6
Connecting a laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Step 7
Hope this helps
Aug 01, 2010 | Acer PD100 Multimedia Projector
Dell Vostro 1510 connects to Sony Data Projector SVGA VPL-C57 shows colour of screen but not content. Can view data when starting up laptop but then shows a blank when I go into presentation. Is there a...
Do you have an SV plug in on both your laptop and projector?..the laptop video out(SV) and the projector video in(SV),if so...try an SV wire connector:)
Apr 13, 2010 | Dell Vostro 1510 Laptop
I can't connect my data projector to Aspire One Pro Netbook. Why doesn't it show my powerpoint presentation?
just connect the vga cable to vga port of laptop and to the projector and in projector choose the source of display vga or pc mode and in laptop press f5 button or right click on desktop and choose the display mode lcd +monitor it will show you the display on projector.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Acer Aspire One PC Notebook
Can't project SONY VAIO laptop onto screen with NEC projector
Change the chord with a chord with a new one preffered by that laptop.
Aug 14, 2009 | Computers & Internet
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Optoma MovieTime DV10 Multimedia Projector Logo
142 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
