Question about LG Cell Phones
I turned on my LG cu545 and got the following message: "Error Fatal file: bio.c line 2561 BIO shared data doesn't exist" The phone is locked and will not turn off
  • schaffin1049 Oct 20, 2008
    Yes...Actually, I remembered to remove the battery after the initial panic (It was the first thing in the AM) which turned off the phone. The phone booted up fine after I replaced it.
    Thanks for the help, y'all
    Master:
  • 848 Answers
Remove the battery .......
and insert it after 20 minutes ...........
it will remove the message ........
Posted on Oct 20, 2008
  • gopinath pasupathy Oct 20, 2008
    do master reset in your mobile .......it will reset the phone to factory settings .........this error mostly occurs due to software problem.......
How to factory recover LG g4 pre-owned Verizon phone
Hi, buddy! Watch this video and use the app to recover your lost data. It's easy to recover what you want. Download from :www.gtrecovery.net
Mar 12, 2016 | LG Cell Phones
How to fix fatal error
In order to fix your phone, you need to be calm and patient. Make a wrong move and no one will be able to help you.
Method A) First thing to do is determine if you can connect your phone to your computericon1.png and open its file-system up. If you can, just replace the files that you messed up with the original files (If you didn't back-up get the files above) and then restart your phone.
Method B) If you cannot access your file-system because your phone is constantly rebooting, the first thing you need to do is turn your phone off. If the on/off button doesn't work, pull the battery out to turn it off (DON'T TURN IT ON). Then connect your phone to your computer (While its off, and it should turn on by itself and go into a charging screen) and see if you can access your phone's file-system, again if you can replace the messed up filesicon1.png, and restart your phone.
Method C) If you STILL can't access your phone file-system, don't fear there's still hope. Some users have reported success using this method, but it may or may not work for you. Try holding all 4 buttons (camera, lock/unlock, and volume rocker) on the side when the phone is starting, see if you can get it to a white screen with information stating "This phone has the IMEI. If you want to make the gang image erase the IMEI," if you see that, connecticon1.png your phone to your computer and replace the files, then restart.
Method D) If you find that you cannot stay in the gang image screen above, meaning it turns blue/black with error fatal when you connect to the phone, then do this: Remove the SIM card out and turn on the phone. Hopefully you will get the emergency call screen to display (where you can only make 911 calls). Connect to your phone now and replace the files.
__________________________________________________ _________________________________________________
I also got the fatal error screen and another way to get it to the gang image screen is to remove your sim card and leave the battery in then plug it into a wall charger and then use the four button thing to take it to the gang screen, after it gets there unplug it from the wall charger and plug it into the data cable and the screen will remain at the same position..
This is Basically a Factory Reset for your phone. Try the other solutionsicon1.png above, then go for this one. Kind of a..Last Resort i guess you could say.. This is also known as the "GrCobb Method"
I had the same type of problem and had trouble resolving it by putting back the files I thought I had changed. I was getting LG's 'blue screen of *****' with a message like Fatal Error: Dog: 1 or something like that. Here is what I did:
1. Downloadicon1.png the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directoryicon1.png with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
2. Get into EFS and connect with your phone. Get to the gang screen on your phone using the steps if you have to.
3. Rename the LGAPP folder to something else (LGAPP_bad). Do not delete it. There are some files that are read only and you get an error message replacing them when you copy the new GAPP on top of an existing LGAPP directory. This doesn't happen if you rename the old LGAPP to LGAPP_bad before you do the copy.
4. Copy the LGAPP directory you unzipped above to the phone and restart it.
That is what I did and it came back to a clean state as if you did a factory reset.
Hope that helps.
Jul 20, 2014 | LG Vu CU920 Cellular Phone
Download LG vue 920 fatal error, file pmapp.c, line 1521, 32KHz sleep xtal failure
Fatal error, means almost the same as it died.
If you can't reset it, I think you have to bring it to a LG certified repair centre. Or start saving for a new phone?
Jul 16, 2014 | LG Cell Phones
Fatal error kernel32,dll skype
Delete the existing Skype files first. It's denying the download over top of an existing file (file already exists).
Nov 17, 2013 | Skype IM
Recover deleted messaging for LG gw300
If your phone run Android OS, you can try to use Tenorshare Android Data Recovery, know more here: how to recover data from LG phone.
Sep 13, 2013 | LG KS360 QWERTY Keyboard Phone BRAND...
Sony bio 2006 home computer, won't go past the (c
Try to Repair your Operating System using Bootable CD.
Your all files and Saved Data will be safe and will not harm by repairing step.
Which Operating System you have on your Computer? Windows or Linux?
Apr 22, 2013 | Computers & Internet
Error message says "An application
I have this phone, you should be able to call your provider on another phone and have them do a hard reset which sets it back to default factory settings.
Good luck
Mar 25, 2011 | LG RUMOR Cellular Phone
My phone is showing blue screen with "error fatal
1. remove the battery and power cable 2. remove the sim and memory card 3. reinstall eveything 4. estart your system
Jan 28, 2011 | LG Vu CU920 Cellular Phone
My lg view is stuck on a blue screen with a code showing....error fatal file dog ui. what do i do can it be fixed?
that is called the "LG blue screen of death"
you will have to restore it to factory settings.
follow the steps below:
1. Download the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directory with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
Oct 08, 2009 | LG Cell Phones
LG KF390q Blue screen within the following message when turning it on: Error Fatal file: dog: UI line: 0 How do I solve this problem?
This is a system failure, the program could be corrupted. To solve this, bring the phone to an authorized LG repair station and have the firmware re-flash to the phone.
Aside from the firmware, there could be some components that needs to be replaced. Hopefully, firmware could fix the problem so that it would not costs you too much.
Have a great day!
Sep 21, 2009 | LG Cell Phones
Cell Phones Logo
62 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
