Maxtor III 500 GB external drive died - Computers & Internet
  • 1 more comment
  • beachbumar Oct 20, 2008
    Actually, I'm trying to find out if there is any way I can recover the data on it. It's a Maxtor One Touch III 500 GB external hard drive, firewire/USB, and I really need the data on it.
    It's an external hard drive, yes. The computer doesn't recognize it, either when connected via firewire or when connected via USB. A light indicator flashes (instead of glowing constantly), and the Maxtor (now Seagate) website said the flashing light indicates a hard disk defect. Since I need the data, I'm trying to see if I can do a user repair, rather than ship it (and my data) away. Doggone it.
    I have a Maxtor One Touch III 500 GB external hard drive, firewire/USB, and I really need the data on it. I'm trying to find out if there is any way I can recover the data on it. My computer doesn't recognize it, either when connected via firewire or when connected via USB (both computer ports have been verified to work with other peripherals). A light indicator flashes (instead of glowing constantly), and the Maxtor (now Seagate) website said the flashing light indicates a hard disk defect and to return the disk if under warranty. Since I need the data, I'm trying to see if I can do a user repair, rather than ship it (and my data) away. Doggone it. I'm more concerned about recovering the data than voiding the warranty.
    President:
  • 1,952 Answers
Have u checked in device manager...whether its enable or not?
Posted on Oct 20, 2008
    President:
  • 1,257 Answers
There are some experts who can do this..If its chip is damaged they can repair and the hard drive will begin to work...
You can not do it yourself so don't try to open and repair..
Ask any local computer shop if they can find any hard drive repair person for you..
    Master:
  • 538 Answers
Sure..let me know where you live, and i will find a service bureau nearby..zip code is fine..
  • 5 more comments
  • A Womans Computer Man
    A Womans Computer Man Oct 20, 2008
    actually, here is the internal fixya list..sorry no search capability..
    click here for those service providors
    the data may be saved..just need to know your location..
    user level recovery is a tad difficult, without the correct software..involves actually removing the drive, and hopefully, it is compatible with your ide or scsi configuration internal to the computer..
    what kind of computer are you using?
    ok..well..then i will need the computer model number, to see if we can do some surgery here..can you provide the computer model number, to see whether this transplant can work?
    If your Seagate or Maxtor external hard drive is not being
    recognized by your Windows PC, whether it is a brand new drive, or one
    that has been connected to your computer for years, this article
    contains some steps you can take to troubleshoot the problem.
    Please consider this article a supplement to the primary, more complete Seagate website external hard drive troubleshooter.
    Is the light on on the front of the drive? Maxtor
    Personal Storage drives have a green light on the front of the drive
    that, when lit, indicate that the drive is getting power. Maxtor
    OneTouch drives have a light on the OneTouch button that, when lit,
    indicates the drive is getting power.
    Is the drive connected to the power adapter? If
    the light is not on, make sure the drive is connected to the power
    adapter and the power adapter is connected to an electric outlet.
    Is the power adapter functioning properly? Make
    sure the power adapter is functioning properly. The power adapter that
    comes with the Maxtor OneTouch drives has a green indicator light which
    should be on once the adapter is connected to an electric outlet. If
    this green light is not on, there may be a problem with the power
    adapter. If the green light on the power adapter starts blinking once
    you connect your external drive to the adapter, this can indicate a
    physical problem with the hard drive. If so, please contact Seagate Support for further troubleshooting assistance.
    Is the power switch on? All OneTouch drives
    (except for the OneTouch III Mini Edition) have a power switch on the
    back of the drive. Make sure this switch is in the on position, which
    is indicated on the switch by the number 1.
    If this is a OneTouch III Mini drive, is it getting enough power?
    If you have a OneTouch III Mini Edition that isn't powering up
    properly, you may need to connect both ends of the USB Y-cable to two
    USB ports on your computer. Because the OneTouch III Mini Edition is
    powered via USB, it may need a second USB connection which should
    provide it with enough power to function properly.
    Is your Seagate or Maxtor external drive connected to your computer through the provided firewire or USB cable?
    If it is, but isn't recognized, you may want to try connecting the USB
    or firewire cable to a different port on the computer. If you are
    connecting the drive to an external USB hub, try connecting it directly
    to the USB port built into the computer. If this is a desktop system,
    it is recommended that you use a USB port on the rear of your computer,
    as front USB ports may prevent your external drive from functioning
    properly.
    ok..that maxtor has a SATA drive..now, if you can simply let me know the pc you have, we can find out if there is even a remote possibility of a transplant
    Master:
  • 848 Answers
Provide more details ........
do you want to buy another one ?
whats your problem ..........
  • 6,487 Answers
Is this an extrenal drive or no? if its an external drive are you saying that your computer wont recognize it when its connected via the usb port if yes did you try connecting it to another usb port or possible to another computer and also try a different usb cable??
  • Mark Gil
    Mark Gil Oct 20, 2008
    Did you try checking if the drive will be working on a different computer or try using a nother USB cable? because if its not recognize on a different computer or with a different usb cable this can be a problem with the drive enclosure and if you want tor ecover the files you can try to remove the hard drive from its external enclosure and connect the drive inside your computer as a slave...
    Genius:
  • 2,785 Answers
If it is warranty then send it back for replacement.
I have a maxtor III usb 2.0 500 GB external hard drive. the light on the front goes out and works sometimes. when the light goes out the external drive gets disconnected . i checked for loose connections....
Possibly, the USB is not receiving current enough and occasionally it resets the USB interface. Try connecting it to another system, or to a powered USB host, and see what happens.
Another possibility (but you'd need to disassemble the external enclosure and connect directly the disk inside to a SMART-capable motherboard) is that the hard disk is developing a fault.
Apr 15, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor external portable hard drive. P/N 9NX2DC-500
first it has to be formated to work with it, use manage by right click on my computer then select disk managment from left pane
Oct 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor hard drive problem
it is a software issue. run the software and apply the password. i had the same problem email me at netrecov@yahoo.com for more assistance
Apr 20, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
The drive is dying. If it is still under warranty, call Maxtor for a replacement.
Dec 13, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
