Question about Kodak EasyShare DX7440 Digital Camera
ON/OFF SWITCH The camera switches itself on and off. Picking up the camera will make it switch on than after coupla seconds it will switch itself off.
  • 215 Answers
It sounds like a bad connection with batteries or battery holder or a loose cable somewhere within the camera. Maybe even a dry solder joint or intermittent fault with the power switch. Unless you know your way around the innards of your camera I'd recommend a qualified tech to take a look. BMW
Posted on Jul 02, 2006
When you switch it on now is shows "CARD IS LOCKED".... I have changed card. switch the tag on the card as advised checked the camera is not full. this is definitely a fault with the camera...
Hello
Have a good look at the second part of the solution given below, in this case it sounds to me like the pin might be your problem. Feel free to let me know if you have any questions.
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Dec 14, 2010 | Casio EXILIM Card EX-S770 Digital Camera
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
Jun 13, 2017 | Gardner Bender #GSW-22 Push Button Switch
Switching on by itself
Hi...
Try covering the little red window that has the wireless remote receiver behind it. See what happens.If the problem quits,your stereo is picking up some other IR source in the room.
Also,shoot some WD40 into the cutout around the power switch
( WITH THE POWER UNPLUGGED) push the switch on/off several times then plug the AC back in.
Jan 07, 2009 | Technics SCEH790 CD Shelf System
DSC-F828 The on and off switch keep turning on.
My friend told me to take out the battery for over one hour and put it back and use the reset button if required. It works o.k. now!
Jul 06, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Camera switches itself on and off
hello guest, I know exactly what your fault is, the zoom switch is faulty. the actual switch on the pcb is jammed and is going to need replacing.
Jan 20, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Ccd tr517
I had the same thing on mine and it turned out to be the on/off switch in the lens head. I took it apart and moved the switch a bit and the problem did not come back for quite awhile. I replaced the switch and it has been fine.
My camera would actually turn on by itself also before changing the switch.
Oct 31, 2007 | Sony Handycam CCD-TR517 Camcorder
Finepix 1400 won't switch on
I read Something Similuar where This Individual Recharged The Batteries And Then Somehow Rebooted His Comp And The Camera Then began To Respond?
Sep 04, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Kodak EasyShare DX7440 Digital Camera Logo
60 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
